Psu how can u identify how much watts ur psu produces???
  • 221 Answers
If the power supply is external (like a laptop power supply) the maximum wattage will be written on the label of the power brick. If it's an internal power supply (like in a desktop computer), you'll need to open the case, and look at the big sticker on the side of the power supply. The maxium output wattage is usually printed in big letters near the top or bottom of the sticker. In a worst-case scenario, the wattage isn't printed on the power supply, and so you'll need to find the model number of the power supply (from that big sticker) and pop that number into google and it should tell you what the power rating on that model is. Good luck!
Posted on Jun 02, 2009
My 1HP160 watt desktop psu went bad. Should I replace it with the same thing or is there something else in a higher wattage that is compatible?
Yes most PSU's are standard fittings. Certianly with HP. 160 watt is a very low spec look at 350 watt at least. Cheap enough to replace.
Dec 23, 2010 | Hi-Pro HP-K1603A3 (HPK1603A3) 160-Watt...
Recommended psu wattage inreplacement to 300watts psu for asusp4p800s-x
the needed wattage is directly linked to the componets you want to use other then the mobo itself. the main power surges are the CPU (takes 40 to 110 Watts) a graphics card (from 5 to over 150 Watts) the Drives (about 25-30 Watts eachs), the RAM and all the other addons and gadgets you build into your PC. Just add the different Wattages together and give it quiet some headroom. I usually drive this kinds of mobos with 400-550 Watts PSU to be on the save side, if i use a more or less "standard" graphics card, and even more with high sophistcated cards or lots of drives or such.
if you "see" low power (Volts) it might also be a problem with a partwise defective PSU.
May 28, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
Whining sound with xion 800 watt power supply.
There is a fan insine the power supply, and also a fan on the CPU. Occasionally there is also a fan on the chassis of the computer itself.
Turn on the computer, take the case off, and listen to identify the source of the noise. If it's inside the PSU, return it and get a new one.
Feb 20, 2009 | XION PSU XION|XON-800R14N 800W RT
Dell GX270 SFF 160Watt PSU - no start at low temperatures
You're on the right track... failing capacitors were a real issue for these Dell PCs (and others), in fact I would be surprised if there wasn't at least one failing capacitor on the motherboard as well.
Not an extremely difficult task though it requires some electronics skill, suitable equipment & appropriate replacement components, try brands like (but not limited to) Rubycon, Panasonic, Sanyo & SamXon you're looking for Low ESR rated capacitors of equal voltage rating & capacitance.
Additionally 10v capacitors can be replaced by 6.3v items as you're only looking at 12v, 3.3v & 5v being produced within the PSU.
Jan 20, 2009 | Dell (HP-L161NF3P) (P0813) 160-Watt Power...
Psu
usually any PSU will fit as long as you dont have a odd case. you can even take out ur old PSU take it to a best buy, circut city, and fry's electronics and ask them for n higher watt of the PSU u already have.
Oct 17, 2008 | E-Machines Computers & Internet
Psu
200 watt max. 19v DC power brick with a 4 pin plug, with two positive and two ground pins. The PSU is unique to the E-bot. I have not been able to find an exact match anywhere. Foxconn no longer sells the PSUs and will not help with tech support in any way. The PSU was originally produced by Fortron Source Power (FSP). When mine went bad, I had to buy a similar looking unit (but with only a 150 watt max rating), then I had to rewire the output cord, because the 4 pin plug had the positives and negatives switched around.
If you need a new power brick for the Ebot, I seriously hope you have the old original unit still. If you do, you can then simply buy any 19V laptop power brick that has acceptable power output (at least 120 watt) and then replace the power output cord with the original one from the Ebot's power supply (some soldering required). It's really the only way to replace the unit.
Jun 23, 2008 | Foxconn eBOT Barebone
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Upgrading power supply
The next time you get a PSU. Tell them what you have. Apparently you got one that is not compatible with your compaq.The power (500 wattage) will work with your MB.
Get an OEM PSU from Compaq(HP).
Dec 02, 2007 | Compaq (253219-002) Motherboard
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
