I have a Wharfedale LCD 1510A TV, recently I connected it to a digital AV receiver and worked perfectly, but recently when I turn it on all i get is a blue screen, no sound or picture from any channel - can you help.
  • 1 more comment
  • ken2646 Jun 02, 2009
    This is not a projection TV, it is a small 15", which I use as a second set, hence wanting to transmit a digital signal to the set from an AV sender / receiver. It worked well but I dissconnected it and took it to my caravan were I connected it to an aerial signal and didnt work.
    When I came home and conected it up again it wouldn't work, just blue screen. All connections are fine I checked them more than once. No spillage occurred and i have now switched it off at the mains for 24 hours.
    Hi Thanks, but what and were is the PP button on my controller, are you aware this is a british TV & maybe you have different names for this in USA if that's where you are?
    Apologies, found the PP button, did as you suggested but no success, still a blue screen, i didn't get any message when i pressed the PP button 3 times.
    Brigadier General:
  • 8,619 Answers
Hi
Please check the connections at the back if they are fine and all the cables are properly connected. The blue screen happens due to loose connections. You can also leave the TV unplugged for 2-24hrs which will reset the TV. If still you get the same issue then you need to check if there is any coolent spill on the board. If the TV is under warranty then it is always recommended to contact the manufacturer.
Please do accept this solution and revert for further assitance.
Thanks
Rylee
Posted on Jun 02, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jun 02, 2009
    Hi!
    First please press the P P button on the remote control 3 (three) times and it will give you access to the blue screen lock command. Then switch the blue screen lock off. This will remove the blue screen and the picture will be restored.
    Please do accept this solution and revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Hi
    The TV defaults to a blue screen because it is not receiving any signals...due to it needing tuned to your local transmitter.
    You need to get in to the installation/tuning menu and try to tune the channels. Also check for the signal cables coming from the AV reciever/cable box.
    Try connecting your tv with a dvd player and check if that works with the player or still it shows the blue screen.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Jun 03, 2009
    Thanks
    Rylee
Sharp LCD TV takes a long time to turn on
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 16, 2016 | Sharp Televison & Video
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
How do I connect my Sharp Aquos to my audio system-- TV to preamp and so on?
hi,
you can connect th analog audio output of your tv to ur preamp's any of the analog audio input, if it is a stereo preamp. if u have a AV receiver, then connect the digital audio output ( optical )of your tv , to any one of the digital input of ur AV receiver.
ok
Dec 20, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Hi, i've been given a Wharfedale LP160DTRHDMI. How do I install it as I have no manual?
U have a LCD tv any models?Just buy a HDMI cable,one side of cable hook to the HDMI in the Wharfedale hub,the orther side to the HDMI LCD tv hub.Power on,play the thing,go to the LCD tv,go in the LCD tv menu pick HDMI 1,2,3 will get the movie or what u playing?If the Wharfedale work.
Apr 14, 2010 | Wharfedale LP160DTRHDMI
No sound output from coaxial port on philips dvdr 3475
try setting your av signal selector to auto. if that daes not work go to your av set click on digital input setuo an make sure you have got one of your coaxial slots asigned to dvr1. you will get better sound by using a coaxial or optical hookup compared to hdmi. i've tryed both. hope this helps you , if it don't email me back at mirbrts5@bellsouth.net. i also has a ppioneer av reciever, so i've been through the same trile and errors
May 02, 2009 | Philips DVDR3475/37 DVD Recorder
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
