Question about Samsung LN-S4051D 40 in. LCD Television
My television set is not coming "ON" when its turned "ON"
I went to turn my tv on, there was no sound and no picture it was like its not turned on, i checked the AC plug it was okay, checke the fuses they were okay, i also checked if there was AC voltage after the swicth, it was there , so now i'm confused, can someone help me solve this problem
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 Philips set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 02, 2009
Pop sound tv went black, went off then back on had sound but no picture, I turned it off and it turned its self back on at this time no picture and no sound. I unplugged tv and when I plugged it back in it...
An electrolytic capacitor has gone bad in you high voltage section of your TV or the high voltage oscilater has gone failed please have tech check and replace
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
Picture went out during thunderstorm. Won't show
The television may be repairable most tv shops ask a $20 fee to look at and tell youyes or know as to how to get rid of it if you dont want to bother with it all take it to your local dump and pay $10 for correct disposal.
Honetly to me it sound like thepower board was hit and can be repaired,
Jul 01, 2010 | Philips 60PP9202 60" Rear Projection...
While watching the TV the picture suddenly went out - still have sound. Turning the TV off and on again does not help - the POLAROID Logo displays, but when the station connects - still no picture
possibly external power supply faulty under load it may fail these power supplies ofen have capacitor failure open the power supply to check for leaking/bulging/swollen capacitor is around 2000uf rated at 12v
Apr 28, 2009 | Polaroid FLM-2011 Television
Turns on But No Picture and No Sound
sounds like it could be a cabling issue, try replacing the cabling (if you have another tv, you can borrow the cabling before purchasing new set of cabling)
Apr 04, 2009 | LG 50PC5D Television
Haier P42LV6-T1 picture
when TV overheats white lines come across the screen
May 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
42' rca problems
my tv did the same thing my power supply board had went out had to replace it now I have no problem did you notice a hiss when you cut it on if so it is the same problem
Apr 07, 2008 | RCA HD52W59 HDTV Projection Television
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Samsung LN-S4051D 40 in. LCD Television Logo
281 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
