Question about Uniden Cordless Phone
Tesco ARC200 Cordless DECT Phone: Batteries will not charge.
The batteries will not charge on one phone, phone works with charged batteries, charger works with the other 2 phones. need circuit diagram for charging circuit of phone.
  • 3 Answers
A new battery is available from
www.espspecialbatteries.co.uk
Posted on Jul 21, 2010
I have just purchased a phone plugged it all in have you to wait till batterys have charged for it to work
Usually you need to wait about 15 hours for the new phone batteries to charge up.
Oct 02, 2016 | Lands Phones
Will not hold charge / shuts off
the batteries may need replacement. 2 aaa size ni-mh 560 mah 1.2 v are required. or the charger may be defective. If the charging light or the battery bars show up in display when placed in the cradle, the charger may not be defective.
Mar 16, 2015 | Uniden DECT 6.0 Cordless Phone ID
How can I get new batteries
Normally in the BT range the batteries are rechargable, hence the base charger, so do not use ordinary batteries. If the phones are not charging, go to boots or tesco and buy AAA rechargeables 2 per handset. Once replaced allow at least 6 hours charge before use. After that just carry on as normal.
Jul 23, 2014 | BT Freestyle 750 Digital Cordless Handsets
Batteries won't charge
There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
I hope this helps.
Jun 18, 2014 | Uniden DECT 6.0 Cordless Telephone...
Handset message "Warning check battery" after replacing new battery
Hello - did you put the phone on the charger with new battery and leave it there for 8-12 hours? If so then you may either have the wrong battery or your phone won't accept generic batteries (if it is generic). You can locate your phone model by looking under the base or finding it on this this site. Sometime it is normal to get an error message if you haven't let the battery fully charge. It may say it is charged but still important to leave on charger over night. Good luck:)
Aug 11, 2013 | AT&T Att Sl82118 Dect 6 0 Digital Cordless...
1 of my trio BT 1500 keeps beeping I have fitted new batteries
Try it in another charger as it sounds like it's not charging, solutions, clean battery terminals in phone, clean terminals on charger, swap chargers
Mar 28, 2013 | BT Hudson Plus 1500 Trio Dect Cordless...
Uniden cordless phone not working
Yr battery is probably Shot. With these type of batteries they can fall over if they go below 25% charge for a length of time. The charger is not charging even though it says it is. If the phone is not to old then get a new battery and try again. cheers
Sep 06, 2012 | Uniden Cordless Phone
[ARC20x User Guide p20: 11 Handset Registration]
To register a new handset:
  1. Press and hold the HANDSET LOCATOR on the base unit until you hear Registration tone (repeated 'beeps')
  2. On the handset, press the PROG then the UP or DOWN button to display "REGISTER"
  3. Press the PHONE/OK
    -> The display shows "BS 1234". If any of these numbers is steady (not flashing), then the handset is already registered to that base unit.
  4. Press 1 to select base unit number 1
    -> The display shows "BASE PIN _ _ _ _"
  5. Key in the system PIN (default 0000) and press the PHONE/OK
    -> The display shows "WAIT _ _ _ _" for a few moments, while the handset searches for a base. Then it shows a list of handset numbers which are still free on the base unit.
    (For example, "1 34 6" indicates that numbers 1, 3, 4 and 6 are free; 2 and 5 are already assigned to other handsets.)
  6. Key in a free handset number
    -> After a moment, the display should show the handset's name and number.
If registration fails...
  • Try again, making sure you begin step 2 as soon ans Registration tone starts.
Nov 08, 2008 | Uniden Cordless Phone
Vtech DECT 6.0
get a multi meter and test the charging unit for 9v. if the transformer output to batteries is other than the 9.6, you will see that output.
it will say right on the transformer what the ouput should be.
it has to be at least what the output of what the battery is.
if it's not you'll need a new transformer.
i've seen this before where the battery output is 9v but the charger is only producing a limited out of around 3v.
Jan 14, 2008 | GE 28112EE2 Cordless Phone
Uniden Cordless Phone Logo
348 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
