Question about Samsung YP-Z5 MP3 Player
Samsung yp-z5 scroll panel stopped working.
Ive had this mp3 player for close to 1 year. it worked perfectly fine up until a few days ago when I tried to use the up arrow on the touch pad. whenever I pressed the up arrow, on the screen, it would just scroll down. although the down arrow will work like its supposed to the up arrow won't.
  • 5 more comments
  • tyler0895 Nov 06, 2007
    my yp-z5 was working great for a year and then the scroll pad stopped working an so i took the pad off and nothing worked so i put it back together an put it in my closet and i was pretty pissed..i mean come on i always worked fin until the warranty wore out but it might noot be there fault well please find a solution...thanks
  • Anonymous Apr 05, 2008
    won't connect to my pc but d battery is still charged
  • KENNEDYG101 Apr 06, 2008
    I'VE TRIED EVERYTHING THTS POSSIBLE IT JUS WONT WORK HELP MEH
  • Anonymous Apr 14, 2008
    same thing to me :(
  • Anonymous Apr 28, 2008
    my scroll and reset button does not work
  • ericain May 03, 2008
    scrolling down doesnt work
  • KENNEDYG101 May 11, 2010
    I NEED HELP I GOT THA AME PROBLEM AS YALL WST SHUD I DO
I have one who do you fix it i need a usb and a the tech pad who do i fit it
Posted on Mar 09, 2008
  • 70 Answers
This is a common hardware fault with this player. I guess it is why the model has been replaced.
The cheapest solution is to buy a faulty player from ebay - around £10 including postage and replace your faulty one. Make sure to check the faulty one does not have the touchpad fault.
It is straightforward to replace the touchpad.
Posted on Dec 22, 2007
My Samsung YP-Z5 player wont respond to charging. Tried plugging into several USB ports on different computers but wont charge. Its constantly displaying .... Low Battery & USB Disabled. I was...
Yes, they only last two to three years.
A search of eBay, a place i look to check availability gives a number available.
Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron.
Otherwise twisting the wires together is probably good enough.
Tape the joins to strengthen and insulate them.
Feb 08, 2011 | Samsung YP-Z5 MP3 Player
MP3 driving me mad
i cannot turn on my samsung 1G mp3 yp-1 after last recharge.
How can i turn it on or reset it?
Mar 15, 2008 | Samsung YP-Z5A MP3 Player
Samsung YP-Z5
From my experience this is a hardware fault with the touchpad. Luckily you can buy a faulty player on ebay and replace the touchpad - make sure the fault on the faulty one is not the same!
The player is is easy to take apart and the touchpad easy to replace.
Nov 20, 2007 | Samsung YP-Z5 MP3 Player
My YP-Z5 unresponsive
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Nov 18, 2007 | Samsung YP-Z5 MP3 Player
My samsung will not connect to my computer
please help!!!!!
i have a samsung GT-S5600V ive installed the software for it 'USB cable' and 'Samsung new PC studio' and ive connected my phone to the computer through the USB cable and its not searching for the device it keeps saying 'the device cannot be opened because another program is currently using it.close the program to connect the device.move to search new device' and im gettin really annoyed PLEASE HELP!
Nov 14, 2007 | Samsung YP-K3 MP3 Player
Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Down scroll
Try reseting the player. It might not work all the time, but this was the first time my down scroll ever locked up on me, and the reset button fixed the problem. It might just be a temporary solution, but at least it's something.
Aug 09, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
SAMSUNG YP-Z5 4 Gb MP3 player
Well i heard of a couple of reasons why this may happen, but i cant promise any of these will work but you can give it a shot. 1. there was a couple of issues with older firmware try re flashing with newer version and then formatting it. 2. i heard that in some cases you will have this problem when you have duplicate songs in it, see if you can go trough your music library to see if you encounter an duplicate songs and delete them, its weird i know but i heard that works.
Jul 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung yp z5 doesnt work!
see the reset button on the bottom? press it. mite have to use a sharp pencil or a pin.
Jan 08, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-Z5 MP3 Player Logo
591 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
