Question about Yamaha RX-797 Receiver
Display panel does not light; sound is ok
I recently acquired a used RX-730 receiver. Seems to work well except that the display panel does not light. Can this be easily repaired/replaced?
    President:
  • Yamaha Master
  • 1,114 Answers
It may not need repair. if you have it hooked up to a TV, by video, s-video, or component. Press the menu button on the remote and you can see the main menu of the unit on the TV. Navigate the menu up/down/left/right/enter until you get to "display". You should be able to turn the display of the receiver on/off. If you don't have the manual. http://www.yamaha.com/yamahavgn/Documents/YEC/Stereo_Receivers/Manual/RX-797_e_U_p.pdf That's the PDF from Yamaha. I haven't used this particular unit, but that's the way it's done on all the other series. ie. RX-V or RX-Z. Hope this helps
Posted on Jun 03, 2009
Out of curiosity, could you please elaborate on your issue. My RX-730 display is completely dead. It should actually have two lights, one general backlight and then the LCD display to indicate station frequency, etc. Does either one of these work for you? If so, which one? Can you check the voltage at the output terminals for your backlight? It is pretty simple, just trace the wires from the display back to the connector header on the board and put your VOM leads across the two terminals with the unit powered up. What voltage reading are you getting. I just checked mine and read about 0.12 volts which seems kind of low for a lamp circuit. I'll let you know what the service manual says when I get my hands on one.
Posted on Jul 20, 2009
Yamaha RX-V660 Display Light Out
if you not tech ..suggest send to service
this problem is display negative voltage missing......or display driver ic bad.....
Nov 09, 2009 | Audio Players & Recorders
No power
Crystal for system micro should be in front panel display and near the lcd display .while your there check solder connections in display board
Aug 05, 2009 | Yamaha RX-V420 Receiver
Yamaha RX-730 Display Does not Light Up
The display is backlit with an incandescent bulb an easy fix. Two wires from power supply to a white plastic hollow reflector assy, similar to the back of an auto headlight assy. unplug at pwer supply and remove bulb from reflector insert new bulb and your done. Be careful not to damage pc board above reflector it's the controller for the LCD dislplay.
Jul 20, 2009 | Yamaha RX-797 Receiver
TXSR875 reciever display
Hi and welcome to FixYa,
Two possibilities:
  • the Pure Audio feature has been engaged. This turns off the receiver's front panel display;
  • heat related issue. A common fault that develops is component failure, specifically, R9304, a 10 ohms dropping resistor connected inline with the +44V display supply.
Should you be considering a DIY (do-it-yourself) repair, please postback for procedures. Otherwise you may have to seek the services of an authorized service center (specially if under warranty) or a qualified professional
Hope that this be of initial help/idea. Good luck and thank you for using FixYa.
Mar 31, 2009 | Onkyo TX-SR875 Receiver
Front display panel
Check for bad connections on the display pins themselves. Specifically, the ones on the ends are the power/ground pins.
Let us know if that resolves the problem. If not, we'll look further into the circuitry.
Dan
Apr 14, 2008 | Yamaha RX-V657 Receiver
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Display is permanently "off" on the Yamaha RX-V620
Sounds like the LED that lights up the display has burnt out. An easy fix, if you're not afraid to take the front panel apart and resolder a new one.
Feb 05, 2008 | Yamaha RX-V620 Receiver
Losing radio stations when switching on and have to press speaker button A
it does not have a battery but a large capacity capacitor that works like a battery. that could be the trouble but rarely happens on new units. the battery is located in the display board near the FL display. odl type uses like a button battery but newer model is just like an ordinary capacitor
Dec 16, 2007 | Yamaha RX-V1200 Receiver
Blank display
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Sep 26, 2007 | Yamaha RX-V870 Receiver
RX-V1500- front panel lights not working
The display on an amp has two components.
A small Lamp (light bulb)
A LCD display with a color filter.
Normally when the display goes out the problem is with the lamp
The lamp on my RXV 870 died after about 9 years of use.
I called Yamaha and was able to by a replacement.
The lamp is an odd voltage 14.5 if I recall.
Looking at the receipt i should have bought 3 for the cost of shipping. It cost about 10.00 cnd,
Apr 02, 2007 | Yamaha RX-V1500 Receiver
Open Questions:
See all Yamaha RX-797 Receiver Questions
Yamaha RX-797 Receiver Logo
391 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
