Question about Toshiba e-Studio 205 Copier
Konica 1212 - no image on the copy, but copier run properly
KONICA 1212
NO IMAGE ON THE PAPER, KINDLY SOLVE IT
  • brian c
    brian c May 11, 2010
    Is there any image on the copy at all, even faintly?
    Can you hear a high pitch whining noise coming from it?
  • George Almeida May 11, 2010
    try making an internal print. The can help in isolating the proplem.
    George
    Sergeant:
  • 210 Answers
This is might be simple solution check how you place you original to Document feeder it should be face up not face down. The transfer/separation corona is not install properly, drum carriage is not install and the locking screw is not screwed in. the last thing my question is did you completely run out of toner? If you did you have run 75 copies before the toner mix in to the developer. there is a shorter way to add toner to the developer but I can not tell you how not unless you are a copier tech.and you should have a extra developer with you in case the developer is over tone. HH
Posted on Aug 10, 2009
My konica minolta c250 is not ready but displaying warming up for a very long time and it did not ready still yet
Warming up means that the copier is not getting hot enough in fuser section, Secondly during that time certain internal house chores are done by the copier to prepare it for READY TO COPY. Are all the image units and toner cartridge OEM!!!??? second has each image unit and toner properly shaking ensure toner in toner cartridges and developer in the image units is spread evenly across each pull each out. shake side ways to ensure spread evenly, last time toner full was run nd gradation adjustments run ?
Dec 02, 2015 | Konica Minolta Konica Bizhub C250 Color...
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
KONICA 7272 CODE SC49-01
Image processing board failure. I would first check all the connection on the image processing board pull each connector one at the time and check for a bent pin, worse case the image processing board is bad, doubt you can find one a Legacy Konica Machine Konica is now KonicaMinolta.
Jan 21, 2015 | Konica Office Equipment & Supplies
On Konica 1212 what does J11 mean and F54?
J11 means Jammed on 1st paper feed tray & F54 means your key swith is Open(disconnected).
Dec 05, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Sc 28-03
Replace the Transfer and Seperation housing which is located below the drum which has several very fine wires that carry HV during the copy process as the paper goes above them and below the drum placing the image on the paper.
May 23, 2014 | Konica Minolta Office Equipment & Supplies
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
I have a Konica 4145 copy machine with error code 60
There is arcing from the transfer corona, HV wires underneath the drum these thin wires provide a HV allowing transfer of the image from the drum to the paper, and allow seperation of the paper from the drum. (p/n 5400-2605)
Aug 19, 2009 | Konica Minolta Office Equipment & Supplies
Toshiba e-Studio 205 Copier Logo
258 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
