Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Optoma 719 - Projector would not turn on.
Projector would not turn on. for a while you could repeatidedly push the power button and it would try to start until it finally started. Now it will not atart at all, and the standby light is not on. I have one of these Optoma 719 in for repair at the moment, which will not turn on at all. Power board checked no obvious burning or anything. Power board is made by that dreadful company Liteon, who make reasonable DVD drives. I cannor even get a power light. Checked power board fuse 4A/250V seems OK 300 volts across lamp socket seems OK. control voltages seem to be strangely absent though i.e 5v 3.3v and 13.5 volts, so which bit of the power board is screwed - ideas anyone
SOURCE: Optoma EP719 lamp does not come on
Ok, so forgive me, I'm going by memory. Take the top cover off (4 screws on the side). Take the top silver shield off, look at the screws and only take off the ones you need. It's ok if you take more off, but its just more screws to track. You will need to take off the back outer cover. You will need to unscrew the hexagonal screws that the vga-out port uses to screw the connector to, as these are holding the back plate on. Once you get in, the board you need to look at is on the bottom back. Look for a capacitor that has a rounded top, not flat like the others. You will need to replace this with the same voltage and capacitance. Try an electronics site on the internet to get the right replacement if you cannot find it locally. Sorry for the poor instructions, but its just been too long. As a practice, take pictures as you go (during removal of parts) and you can use them to reinstall. Hope this helps as mine is still working.
Posted on Sep 09, 2008
marsrover
  • 682 Answers
SOURCE: projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
Posted on Sep 22, 2008
  • 4 Answers
SOURCE: Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Posted on Mar 10, 2009
vortash
  • 431 Answers
SOURCE: optoma projector switches off after 5 mins
AS regretable as this sounds component failiure was my first thought .. It's not the bulb temp sensor as the fan is opperating and that usually cuts all power .
You may find that as you have a bulb ( usually worth more than the units they reside in ) rather than a repair another unit of Ebay would be a safer and more economic conclusion ... Regards Vortash
Posted on May 10, 2009
vortash
  • 431 Answers
SOURCE: Flashing standby,power on,lamp lights with no fan
Most problems with the lamps are covered in the manuels for these projectors , however none user technical difficulties are not .. ie where it is needed to open the unit not recomended to the untrained as a screwdiver in the wrong place can cause irepairable harm let alone death ?
To check if it is your bulb simply take the unit to an engineer for an estimate usually free at least you will know whats wrong and can go from there .. and if you do have a working bulb an ebay replacement is probably the cheaper conclusion to your problem ... regards Vortash
My hd20 has a power-icon light of amber, when power button is pushed it goes to flashing green and it doesn't turn on, just flashes green
Have you tried decreasing the resolution of the computer?
When the resolution is too high for the projector, something similar to your description happens.
Oct 23, 2011 | Optoma HD20 DLP Projector
Lamp comes on briefly and then goes out
Check poewer connection
Check if fan filder is dirty ( if it is just hoover it out)
If "lamp" light on top of the projector blinks or stays lit - lamp probably faulty
How old is the Projector/lamp (average lamp life is around 2000-3000 hours)
Mar 01, 2011 | Optoma EP719 DLP Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Power on, no light...worked in the test run
can you enter the setting and check bulb life timer and if you can reset it?
please feeb back
Apr 18, 2010 | Optoma EZPro 719 DLP Projector
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Jan 31, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma 716
on the projector, restart your laptop/computer, this will detect automatically. if not then try display settings to 800x600.
Dec 13, 2008 | Optoma (BL-FU180A) Projector Lamp for...
Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
195 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
