Question about Fellowes FS5 Shredder
Kindly help in repair of my Fellowes FS5 shredder
My paper shredder motor is running but the cutting cylinders are not turning. This happenes after it has been overloaded with too many papers at a time beyond its capacity.
  • Anonymous Mar 17, 2014
    fellowes dm12c paper shredder won't stop running
    Scholar:
  • 102 Answers
You have a broken or stripped gear
Posted on Feb 22, 2008
I have the same problem with this model shredder. I spent 1 hr to open it up, and confirmed the PLASTIC gear that turns the cylinders are destroyed! That is why even the motor runs like crazy, but the cylinder cutters do not move at all. Why the engineer didn't design to put in a metal gear? Is it more durable than a thin plastic gear?
Posted on Apr 12, 2010
Motor problem
It sounds as if the SafeSense is improperly shutting of the forward sensor. Call Fellowes and see if they can help.
If you do not have the manual use the link below:
Fellowes Shredder Manuals
Aug 18, 2014 | Fellowes 75cs Cross Cut Shredder -...
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Cutting gears do not turn while feeding paper, but the motor runs
If it is in warranty return it . If not the gears are probably damaged and repairs are expensive.
Mar 10, 2014 | Fellowes FEL3831001 C-325Ci Jam Proof...
Shredder #FS5. Blows the circuit breaker each time I move the starter to the start position. Every part of the head is clean of paper, etc.
It sounds like the cogs that drive the cutters are damaged or the spindle on which they run is bent. It requires stripping down the machine to see if this is so. It is very rare that any repair can be done. Looks like a new shredder...
Jan 19, 2014 | Fellowes Office Equipment & Supplies
Led sensors on the bottom
superflykitt:
Disconnect the power cable and remove the cutter head from the top of the paper bin. Turn the shredder head upside-down and remove the screws holding the shredder head cowling together. Open the cowling and you will see the slot where the sensor fits (on one side of the paper feed slot bottom side.
Aug 29, 2012 | Fellowes FS5 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
Shear pin ??
You most likely have several teeth broken off the drive gear that drives the cutting block. Not too difficult to replace but you need some special tools. A deep well socket (I think it's about a 3/8") to remove the cutting block and replace the broken gear. The gear should be available from a Fellowes dealer, or they might sell it to you direct if there is no dealer near you.
Let me know if this helps.
Aloha,
Bill Monroe
Oct 15, 2007 | Fellowes 220C-2 Shredder
Fellowes FS5 Shredder Logo
580 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
