Question about Ford 8n,9n,2n, Tractor Starter With Drive
Wireing amp gage for 9n tractor
Want to put a new amp meter on the 9 n tractor i have 6 volt.the other one was not hook up.would like to know if you come off the reg. or what.thanks
2 Suggested Answers
  • 79 Answers
SOURCE: install distributor points on ford 9n process needed
try this site... http://www.ytmag.com/atrp/specs/ford.htm
Posted on Apr 08, 2009
Kohler 22 hp sv620 charging system problems
Check for dirty,corroded or loose connection at the volt meter gage or light, the current for charging runs back through this gage a lot of the time to charge battery.
Oct 03, 2014 | Garden
Do not have spark on plugs
You need to check the spark plug wires. Check the continuity with an ohm meter if you have one. Rule of thumb is 10000 ohms resistance for every 12 inches of wire. Also make sure to check the coil as well. This should be located at the other end of the spark plug wires. Hope this helps and good luck.
Jan 19, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
My ford 8n starter only clicks, solinoid ok
Are you getting same voltage on each side solinoid when key turned.
Feb 28, 2013 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 9n converted to 12 volt alt still 6 volts at dis. runs rough till i jump 12 volts to coil and then it runs good. Will this damage coil and points?
If you are doing 6 Volts at the distributor you must either have Resistor wiring or a separate resistor in the system. They make both 6Volt and identical 12Volt coils for your unit.
You will eventually burn up a 6Volt coil if you use 12Volts on it. There is an aftermarket company which has Antique supplies. Carpenter(Maybe John) has supplies for Tractors, cars and trucks that are earlier models.
Do a Web search using his name and marry it to Tractor parts, etc.
Sep 09, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
Should i have a continuity reading from the power lug on my 9n starter to the frame? i have removed the slipcover and the armature turns freely but when i put a battery charger set on jump across it it...
is this 6 or 12 volt? also is this positive ground or negative ground? if you pull the starter and put it on a bench ( lets say this is neg ground and 12 volts) put red charger clamp on the post and touch the black clamp to the casing (where it bolts up) it should turn over. things would be hooked different if its 6 volt or if its pos ground
Jan 07, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
No spark at spark plug center of Coil
2000 ford escort ZX2. 4cyl . No spark at the spark plug. Wires are good.
Jul 23, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Need a picture of 9N points so I be sure if I put it back right.
Hey Andy..my name is Keith..and i have 9 Ford tractors..i have 9N's,2N's and 8N's...and i dont know of any site that has the manual on it..and the maintenance manual isnt expensive..and if you are going to do your own mechanicing..you will be glad you have a manual...i hope this has helped..if not please write back
Jun 26, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
No spark to my ford 9n tractor
you are in the wrong place that is the battery regulator. go to the distributor and pull the cap where you see the four spark plug wires. Inside you will see a set of points and a condenser. there you should have 12 volts. Get back to me after that. donnyb60
Mar 22, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
How to measure watts
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
279 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
