Question about KitchenAid Superba KSCS23IN Side by Side Refrigerator
Fridge does not get cold
The freezer is working but the regular fridge is not staying cold. The indicator is moved to "coldest" and it still does not work. I've tried defrosting twice but the same problem exists. Also, the ice dispenser is not dispensing ice. This all started at once. Anything I can do to solve this problem? Thanks for all your help in advance.
  • 1 more comment
  • Reds4002 Oct 25, 2007
    Thank you very much for your help, but there is no frost buildup. Also, the control to the freezer is in the middle setting - no prblem there. It's the other side of the refrigerator that is not staying cool.
  • Anonymous Feb 01, 2008
    Our problem started with freezer not staying cold, we defrosted it and that seemed to fix problem for about five days and then refrigerator started not staying cold, but freezer seems to still be working fine. Also our ice maker went out about six months ago. Is any of this related.
  • culbert_10 Jul 20, 2008
    My freezer is working fine, but my fridge is on the max setting and not getting cold?
  • 291 Answers
If your getting frost build up in the freezer..u said u tried defrosting... is frost building up it freezer?
IF so you have a defrost problem...bad  heaters, defrost themostat or defrost timmer, if ya need more help post more info
Things to check
Check freezer...
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Allowing.. MORE AIR.. to refrigertor side
Posted on Oct 25, 2007
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Buy a new one.
Posted on Jun 04, 2008
It is a small freezer on top and fridge on bottom my freezer working fine but my fridge wont make things cold ?? what can I do ??
Check that the freezer thermostat is set halfway not fully to the coldest setting.If thats ok then get the fan motor checked.
Jan 16, 2016 | Refrigerators
Freezer is working properly but fridge is not staying cold?
is the fan on in the freezer?? if not then you need a new evap fan..also check to see if there is frost build up on the back panel in the freezer section if so then you have a defrost issue could be a bad bandaid the problem..defrost the freezer back panel so air can flow into fridge side, but you will need to address the problem within a week or it will build up again
Apr 05, 2012 | Refrigerators
Freezer not cold enough
setting the freezer at 7 opens the baffle from the freezer to the fridge to make the fridge colder. It works completely opposite than a person would think. Feel in the back of the fridge with it on this setting. The freezer is dumping all its cold air into the fridge thus equalizing the two parts. if you move the selector to 1, you should feel the air from the freezer cut off in the fresh food compartment. try a setting in the middle and let sit for 24 hours. Hope this helps
Jan 25, 2012 | Amana Refrigerators
Temp in refridgerator is 40 degrees on bottom shelf with temp gage turned to coldest setting. Is this right?
the normal temperature for a refrigerator is 35-40 degrees F, so 40 at full cold setting is not correct.
If this is a side-by-side or top-freezer, make sure that the air vents between freezer and fridge are not blocked by food items or ice.
Make sure defroster operation is working normally as ice will block airflow.
Also, there is a circulating fan in most models that moves cold air from freezer to fridge. make sure that's working.
Oct 21, 2009 | Refrigerators
Fridge & Freezer won't get cold, but air is blowing
Is the compressor in the lower back working. You may short of gas . have it regassed
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool intgrated fridge/freezer is not keeping
7 is coldest. but how cold is the freezer? all cold is made in freezer. ma be developing a frose problem
Jul 06, 2009 | Whirlpool ED2GHEXN Side by Side...
My fridge isn't cold.
so get the gas filled in ur compressor
Jun 25, 2009 | Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
sounds like the internal fan is not working ,and on the same circuit as the dispenser.
I assume the tray is full of ice but not dispensing.
you likely have a failure at the circuit junction splitter board.
its just a board with a bunch of wires connected , usually in the rear .
Jun 04, 2008 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
285 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
