Question about HP Office Equipment & Supplies
" Error : invalid software CRC
Printer doesn't print the page in Accel-a- writer 4G. Duplex light blinks i red. Message on the panel is " Error : invalid software CRC" Please help me to solve the problem
SOURCE: Front Paper Jam
I'm not 100% sure that this will work. I have a 3N, when we first got it I had the same problem. After clearing the jam - You have to open the top portion of the printer. Even if the jam is no where around that area... the printer won't reset itself until you lift that top piece. I even tried to turn it off, thinking it would reset...it didn't.
I know the 4g is much newer then mine...but being it's the same company.. this problem might be fixed the same way.
Good Luck.
Posted on Feb 12, 2008
oldnovii
  • 667 Answers
SOURCE: OS X Driver download
Here is the link for your driver. Just scroll down to driver section, choose Mac OS X and then click on the download arrow. Save it in a place you'll know where it is. If this fixes your problem please rate as fixed . Thanks.
http://www.xante.com/support/aw4g/
Posted on Apr 03, 2008
oldnovii
  • 667 Answers
SOURCE: accel-a-writer 3g for leopard
Yes. If you need the driver here is the link. Just scroll down to operating system and choose Mac OS X. If this takes care of your problem please rate as fixed. Thanks.
http://www.xante.com/support/aw3g/
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Posted on Dec 27, 2008
gwbm
  • 353 Answers
SOURCE: printer showing error
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. This is quite straightforward once you know what to do.
If you decide to have a go at replacing the ink pads yourself, post a new comment, and I will provide further help.
Posted on Feb 27, 2009
How do I replace a fuser for a Xante Accel-a-Writer 4G?
dear please find back cover and open it found big unit of printer called printer fuser assembly.removed it carefully you need one Philips screw driver,losses the two screw after that you removed screws slide it right side if you stand back of the printer,however after remove the fuser assembly you can installed it new in the Xante 4G printer when you install slide fuser to left side and alignment carefully,hope you understand.
thanks.
Jun 19, 2014 | Xante Accel-a-Writer 4G Laser Printer
Dr Printer error Unable to connect to the server
Dear
You can use EPM(easy printer Manager) or smart panel. These files can down loaded from the samsung site. install and run in the PC it will show the status of the printer.
The red light blinks and printing is possible means get ready to replace the toner cart. with a new one.
Thanks. Printer Support SAMSUNG India
Apr 25, 2012 | Samsung ML-2510 Laser Printer
Error 49.4c02 comes up whenever i want to do duplex printing
Hello thanks for using FixYa
This is a critical firmware error that occur which cause the processor on the formatter to abort operation.This type of error can be because of invalid print commands,corrupt data,or invalid operations. Sometimes electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables or poor connections,
To solve this try this solution step by step
  • Turn the printer off and then back on.
  • Try printing a job from a different software application. If the job prints, go back to
  • the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
  • f the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
  • Turn the printer off.
  • Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
  • Remove all EIO devices from the printer.
  • Turn the printer on.
  • If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
  • device.
  • Replace a DIMM or EIO device if you determine that it causes the error.
  • Remember to reconnect all cables that connect the printer to the network or computer.
  • If the error persists, final option is replace the firmware
    I hope this solution will helpful 4 u
    Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
    THANKS & Keep Using fixya
Jan 21, 2011 | HP LaserJet 4250dtn Printer
Xante accel-a-writer 4g for mac OSX 10.6
I haven't checked in a while. Xante told me when I called them that they were not planning to make updates past the current version of the 4G OS X drivers, as the machine was no longer in production. They said the driver should perform adequately on current versions of OS X even though it was not initially designed for them (as they did not exist when the driver was created).
I found this to be untrue in my case. The drivers did not allow me to print consistently from 10.5.8 on an Intel Mac Pro.
My solution was to activate the print server on an Xserve running the Tiger server version of OS X, install the Xante driver there (since it was designed to run on that version of the OS), and now my newer macs can use the printer without issue.
Apr 20, 2010 | Xante Accel-a-Writer 4G Laser Printer
49.4co2 service error will not clear
Error 49.xxxx - this type of error can be caused by invalid print comands, corrupt data or invalid operation...try this steps to resolve... :
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
program or print job, contact the
4 If the message persists when using
different software programs and
attempting specific print jobs,
disconnect all of the cables that
connect the MFP to the network or a
computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory
cards. Do not remove the firmware
memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears,
reinstall each DIMM, flash-memory
card, and EIO device individually,
making sure to turn the MFP power off
and then on again as you install each
device.
10 Replace the component that caused
the error message.
11 If the error persists, replace the
formatter
Jan 06, 2010 | HP LaserJet 4650 Color Printer Manual...
Com.lexmark-commProblem-warning
try this. Some of the terminology may vary as I had the solution in german. It came from Lexmark.
Open
http://localhost:631
-     click add printer
-   enter a name for the printer eg Lexmark or troublemaker ;-)
-     click continue
-    from the list chose 'LPD/LPR Hostprinter' and click continue
-     in tne next window enter lexnet3://IP (of the printer):1
-     click continue
-     chose Lexmark and click continue
-     chose your printer type
-     click add printer
This worked for me after reinstalling the printer via cd software.
Otherwise try the usb cable, you then have to go to printer preferences and change the usb printer to standard.
Strangely enough my printer used to work fine via W-Lan, suddenly I received that error. Perhaps du to an update to 10.5.6? I don't know. Hope thet helps, best regards Peter
Nov 24, 2008 | Xante Accel-a-Writer 4G Laser Printer
HP 4350 ERROR MESSAGE: 49.2F90
he printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Front Paper Jam
Good Luck.
Jan 05, 2008 | Xante Accel-a-Writer 3N Laser Printer
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
83 people viewed this question
Seeker5211
Seeker5211
