Question about Microsoft Windows XP Professional
I am having a problem in opening partition of harddisk. whenever i am opening by clicking the drive C:\ or any other drive the message appears " this application cannot be run in Win32 mode
  • 67 Answers
Try a cold reset of the computer buy un pluging it then pluging it back in
Posted on Jun 02, 2009
Tip
If you get message: " boot disk failure" then follow this tip
1)If any cd or dvd is there in the cd or dvd drive remove them first then try booting
if problem persists then
2)check the boot device priority in the BIOS menu,change the boot device priority if required(change to 1 st boot device floppy, 2nd harddisk drive,3 rd to cdrom drive something like this)
to go to bios setup press del or f2(it depends if del key doesnt brings you the bios utility then press f2) at time when you switch on the pc ie at the time of booting the pc ,
3)check whether the harddisk is detected or not in the bios setup
if it is not detected then just open the CPU & check the bus & power supply cable connected to the harddisk remove them & reinsert them ...
if required then replace with the new ones ....
if the problem persists then
4)the operating system might have got corrupted just reinstall ....
5)the harddisk partitions might have got corrupted or crashed ,just try partitioning them again and by installing the operating system.
on Aug 28, 2008 | Compaq Presario 5000 PC Desktop
I had two partition in my external harddisk...but now it shows only one partition when I plug into my computer. Moreover, the one which is shown also opens up quite slowly...please advise.
Connect the WD device
Click Start
Right-mouse click My Computer
Click Manage
Click Storage
Click Disk Management (local)
Do you see a "map" of the two partitions on the device?
It's possible that the disk-drive is "dying".
So, make a backup of the files on it, before it's "too late".
Then, if the WD device is still under WARRANTY, exercise the warranty to get a free replacement.
Oct 11, 2010 | Western Digital Elements powered by WD 320...
Lacie drive can't display in my computer
First of all make sure, all connection in properly connected. Then go to Start>Control Panel> Add Hardware > Then it will search for hardware & new drive will display on my computer. If problem continues make sure you have already made partitions for hard drive if you not credited it make partition of hard drive it will work fine i am sure.
Thanks.
Happy to help you.
Apr 24, 2010 | Microsoft Windows XP Professional
I have install external harddisk in slave, that hard disk is sowing in disk managment but not working
HAS THE HARDDISK BEEN ASSIGNED A DRIVE LETTERIN DISK MANAGEMENT. IF NOT RIGHT CLICK THE DRIVE AND CLICK ON "CHANGE DRIVE LETTER". YOU MIGHT EVEN HAVE TO PARTITION AND FORMAT THE DRIVE TO GAIN ACCESS.
Apr 09, 2010 | Computers & Internet
I got a problem with my toshiba harddisk,not able to operate it
If you are using windows, and this is not your only drive, right click on my computer - select "manage" - when the computer management window opens, click on disk management. Find your toshiba drive. From this console you can initilialize, partition and format the drive. Another solution is to download and burn the opensource live CD called Parted Magic at this address: http://partedmagic.com/download.html. You can boot and run this from the CD. Start the partition manager, locate the Toshiba drive, and select  Set-up a new filesystem (DOS) - you will be able to format the entire disk in nearly any filesystem available (you will most likely want NTSF of FAT32) - apply changes and viola!
Hope these answers help. If you have nay questions, dont hesitate to email me.
Mar 20, 2010 | Toshiba MK3008GAL Hard Drive
Laptop hard drive
Restart your system in safe mode...(If you dont know how to, it is :- When you power on your system, keep tapping F8 key, then a screen will appear which tells you to choose from it, so select Safe mode Startup from here)..., then after you have bootup in safe mode, open my computer, and right click on your harddisk, then go to properties, then tools, then Under Error Checking, click on Check Now tab, Then select the two options there, which are Automatically Fix File System Errors and Attempt recovery of bad Sectors, then click on Start, it will then prompt you that it wants to reschedule it to next System restart, so accept it and restart your system, when your system restarts allow it to scan your harddisk fully. Incase you have two or more partitions, try and do the same thing for ALL of them.
This method will save your harddisk, depending on how bad it has become.
Hope It Helps.
Jul 10, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
3 partitions missing on a 250gb SATA hard disk
i think you just got corruption. possibly heat related. or rootkit. uhh dynamic isn't right i think its logical .. right click the drive letter lower section and convert is best bet. i also dabbed with ptedit32 from bootable cd ubcd4win.com to fix lost partitions in prior experience.. but it was 1 partition and i found lba and other settings on drive sticker.
Jul 09, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Missing Operating System error
your bought compag computer is a new one , because that error is appears only if the hard drive or the harddisk is defective or damage. Your installation of windows xp is finished totally because sometimes the error is appears because the system installation is not finished and the os system cannot read. try to re install again the windows and delete the old partitions and create again if the problem is the same even there is no error in the installation until it's finished i say that the problem is in the harddisk. Maybe the harddisk develop a bad sector in the master boot record of the hardrive
Apr 15, 2008 | Compaq Presario 700 470024-192 Notebook
Microsoft Windows XP Professional Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
