Chemicals in house from pool when running air conditioner
I have a pool right outside my backdoor on a slab.When I run the air condition I think chemicals are coming in the house. Can this be?
  • 83 Answers
There is a small possibility that the air conditioner is sucking some of the air outside. If you're using a window type a/c, there is a small fresh air intake vent you can open and close. If your using a wall type or free standing a/c, fresh air would only come from opening doors or windows. Using a centralized a/c has a fresh air intake and that could be the cause of your problem. The solution would be an anti-odor filter.
I hope this helps.
Posted on Jun 02, 2009
Air conditioning condensor on side of house not working
sounds like you need to check your run cap it is silver in the outside unit and it runs the compressor and fan motor. Check on the capacitor what size it is and replace it for example 45+5 uf.
Sep 07, 2014 | Carrier Heating & Cooling
How do i get AC to work?
air conditioners and refrigerators work the same way. Instead of cooling just the small, insulated space inside of a refrigerator, an air conditioner cools a room, a whole house, or an entire business.
Air conditioners use chemicals that easily convert from a gas to a liquid and back again. This chemical is used to transfer heat from the air inside of a home to the outside air.
The machine has three main parts. They are a compressor, a condenser and an evaporator. The compressor and condenser are usually located on the outside air portion of the air conditioner. The evaporator is located on the inside the house, sometimes as part of a furnace. That's the part that heats your house.
The working fluid arrives at the compressor as a cool, low-pressure gas. The compressor squeezes the fluid. This packs the molecule of the fluid closer together. The closer the molecules are together, the higher its energy and its temperature.
The working fluid leaves the compressor as a hot, high pressure gas and flows into the condenser. If you looked at the air conditioner part outside a house, look for the part that has metal fins all around. The fins act just like a radiator in a car and helps the heat go away, or dissipate, more quickly.
May 26, 2012 | Sunpentown SPT WA-9040DE 9,000 btu Dual...
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
Can be the unit don't have enough gas?
Yes, you could be low on refirgerant. You should have a air conditioning technician test it.
Jun 23, 2009 | Weather King 10AJA3601AH Air Conditioner
Heat pump not cooling after 1 hour
Yes it is true . Sound like you are low on freon the unit is shutting off on the low pressure switch or high pressure switch is the outside unit clean ?you may need service. Tom
Jun 17, 2009 | Carrier CARH09K Air Conditioner
Heater air conditioner unit does not expel air
unless you have zones installed i.e. day and night you will probably find that the main duct off the unit has fallen off
Jun 15, 2009 | Heating & Cooling
Fan running constantly in the house
Check t-stat and make sure fan is set to "Auto", that might be why fan is running all the time, or it could be a fan relay that is stuck closed. It sounds like you A/C is over charged or you have a bad high pressure switch, this was a common problem with this manufacture especially in the heat mode.
Apr 24, 2009 | Ruud Central System Air Conditioner
Fan is still running in house constantly
Check your wall thermostat to make sure the "fan" switch is in the "auto" position. If it is set at the "on" position, the indoor fan WILL run continuously. Not really enough info as to what type of split system you have. Gas? Electric? Heat pump? Oil? Wood? Newspapers? See what I mean? Is it variable speed? Do you have a "special" thermostat for certain operations? Does your system incorperate inverter technology?
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
