Question about HP Pavilion dv6000z Notebook
Dont cherge the battery, motherboard problem
My hp 6910p will not charge the battery both battery and charger are check with out problem. i know the problem is on the motherboard. do you have a sevice manual or do you know where the 7volt from the charger go on the motherboard i think the problem is there. Best regards Roland
    Problem Solver:
  • 18 Answers
Howdy,
Try this:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01566975/c01566975.pdf
This is a PDF (Portable Document File) It must be viewed in Adobe Reader or Foxit Reader. I highly recommend Foxit Reader. It is much smaller and faster on your system. So much so, that I uninstalled Adobe Reader and put Foxit on my machine!! Free Open Source is always the BEST!!
Foxit Page:
Downloads Latest Version
Direct Download Link:
Foxit Reader 3.0 Build 1506(exe)
In addition, when you are viewing the manual in the reader, you can also click the save button and put the PDF file on your desktop and view it whenever you like offline. Or take it with you on a jump drive. Good Luck!
J
Posted on Jun 02, 2009
Ematic egp008 tablet. Can I charge it through the USB port?
Everything I was able to find says "Will not charge through USB". Also saw a lot of complaints about how short the battery life is. About 6 hours. Turn off WiFi if you are not using it. Will make battery last longer.
Jul 04, 2015 | Tablets & eReaders
My battery (on my HP Compaq 6910p) was charging just fine until I recently upgraded my Windows XP Pro OS to Windows Vista Business. Now the battery icon (in the lower right hand corner of Windows) is...
If you are sure your charger is good check the Compaq site for updates for your computer. Vista had lots of problems, I would suggest updating to at least win 7 pro if it's an option.
Jul 05, 2017 | Computers & Internet
MY Compaq 6910p Laptop powers on for about 3 seconds and then powers off when the battery is installed. With AC power this sequence continues nonstop. I have check the battery and the power supply with...
There might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 08, 2010 | HP Compaq nc6320 Notebook
My battery dies yesterday, when I try to cherge it...
Hi, when a message comes up like that, it means your battery is not original and does not work with any charger. You need to replace the battery with an original battery before it will charge.
Take care.
May 21, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Problems with the ac smart adapter Hp Compaq 6910p
You could possibly have a loose dc jack.Being able to wiggle it around and getting it to work tells me that the jack is probally going out.That wiggling your doing can cause an arc on your system board,which can short out your board.Stop wiggling your power supply adapter in your dc jack and take your computer to certified repair shop and have your jack checked.Best to rule this out first ,so no damage is done to your board.If you jack test good ,then replace you power supply....Good luck
Apr 08, 2010 | HP Smart Buy- HP Compaq 6910p Notebook PC...
Hp pavilion d6000 laptop chaging problem
1.take the battery out from the laptop and just wipe it with some clothes(that is used to clean glasses) put it back..
2.if it not solved...you have to change your battery that's confirmed..
3.when the battery is fault you get error like this...when i get this fault i took the battery and just wiped and put it back...
"DONT FORGET TO RATE THE SOLUTION"...
Apr 03, 2010 | HP Pavilion dv6000z Notebook
Compaq HP 6715s Laptop not charging!
If you can determine that it is not the battery just going bad, then most likely it is a problem with the motherboard. I actually have this same problem, and have not been able to find a quick fix.
HP has a battery tester tool. If you are able to use this, then you are one step ahead of where my HP laptop is. I tried running this and it insisted that I did not have a battery installed, or that it was dead. If you have this same problem, then it looks like it might be time for a new motherboard.
In anycase, it might also be worth the time to try draining the battery completely and attempting to charge it back up. According to a few other sources, the laptop can sometimes get confused and think that a full battery is calibrated to be a low battery.
Jul 04, 2009 | HP Compaq nx7300 Notebook
HP Pavilion dv6000z Notebook Logo
250 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
