Question about Dell PowerEdge 1600SC Server
Corruption exists!System halted?
Dear sir,
ATI RANGE SDRAM BIOS R0482P/N GR-XLdelsBy.Q12-4.333
Invalid Memory configuation detected potential for data corruption exists!
System halted!
My server i,e Dell poweredge1600sc shows system halted problem so what to do?
Dell Poweredge 1600sc
S/N BTU2B18
Model:8mm01
  • 53 Answers
You have a bad memory stick.
Posted on Jun 03, 2009
When my laptop boots up it says operating system not found
Not good. Check your bios for correct drive for boot up, but it sounds like yoru hard drive is not being read....
Oct 26, 2010 | Acer (ACERMOTHERBOARD)
What Ram to buy for 1.2 GHz Intel celeron Compaq 5000 desktop currently with 256MB of RAM
You have to purchase SD RAM how much? depends upon the BIOS. Kindly let me know the bios version for accurate solution.
Jun 13, 2010 | Compaq Presario 5000 PC Desktop
Will 1gb ddr2 800mhz ram support intel102ggc2
The board has two 240-pin DIMM sockets and supports the following memory features:
  • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
  • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
  • 2 GB maximum total system memory
  • Minimum total system memory: 128 MB
  • Non-ECC DIMMs
  • Serial Presence Detect
  • DDR2 533 or DDR2 400 SDRAM DIMMs
Note
To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
May 27, 2010 | Intel D102GGC2 Motherboard
Sony Driver
Without the model number the above is meaningless.
Jul 30, 2009 | Sony Computers & Internet
Max RAM for Intel 102 GGC motherboard
Thanks to Intel website The board has two 240-pin DIMM sockets and supports the following memory features: * 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts * Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported. * 2 GB maximum total system memory * Minimum total system memory: 128 MB * Non-ECC DIMMs * Serial Presence Detect * DDR2 533 or DDR2 400 SDRAM DIMMs Note To be fully compliant with all applicable DDR SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance. If non-SPD memory is installed, the BIOS will attempt to correctly configure the memory settings, but performance and reliability may be impacted or the DIMMs may not function under the determined frequency.
Jun 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
I wanna know about the compatible ram for my intel d 485 gally mother board with 1.7 ghz processor
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
CAUTION:
Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note:
To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
I hope it helps!!!
Nov 28, 2008 | Intel D845GLLY Motherboard
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Upgrading RAM
Yes that should not be a problem as DDR is backward compatible with the slower speeds so the faster RAM, will just slow down to match. These are the only conditions listed so as long as the stick you have doesn't fall under this criteria you should be good.
he D845GLVA board provide the following memory features:
  • 2.5 V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered single-sided or double-sided DIMMs
  • DDR266/200 MHz SDRAM DIMMs only
CAUTION:
Do not use ECC DIMMs with this board. Using ECC DIMMs could damage the board.
Integrator's Notes:
  • Registered DIMMs are not supported.
  • Double-sided x16 DIMMs are not supported.
  • If a full-length PCI add-in card is installed in PCI bus connector 1 (the PCI bus connector closest to the processor), remove the add-in card before installing or upgrading memory to avoid interference with the memory retention mechanism.
  • This board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated (currently validated up to 1.0 GB) on this board.
Note:
Enjoy the increase in RAM,
Lee
Jun 14, 2008 | Intel Desktop Board D845GLVA...
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Server
Hey there chandru 2020, the configuration problem which you are experiencing is related to the positioning of your ram in the appropriate slots. Servers work with matching pairs of ram, installed in either two, four or eight sticks of memory. The placement of less than a full set , in your case two minimum is also very specific. You should go to the Dell website to access configuration diagrams for your server model. Also check to ensure your ram is compatible, and try installing just one pair at a time. There is also a possibility that a blank may need to be inserted in empty dimms. I hope this helps. Good Luck!
Jan 28, 2008 | Intel D845GVSR Motherboard
Dell PowerEdge 1600SC Server Logo
682 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
