Question about Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range, oven doesn't hold consistent temperature.
Oven does not maintain temperature while cooking. Oven will come on and preheat as it should but then temperature drops while cooking and remains below preheat value. Every 15 minutes or so we set the temperature to 5 degrees higher and wait for the preheat just to keep it going. The self clean function and broil work OK. I have changed both the thermocouple and the control board. Thanks for your ideas. I have problems with the oven temperature being all over the place, though usually low, but not consistently. Not sure if I should replace the sensor, which is about $75 or the ignitor. Any advice? Thanks
2 Suggested Answers
SOURCE: Hotpoint RGB745 Gas Kitchen Range
I eventually replaced the oven ignitor. That has solved the problem.
Posted on Aug 29, 2007
Hotpoint Gas Range does not hold temperature
We had the same problem, my husband took ours apart and noticed a loose wire off the relay board for the oven. So far it's working again, we had it at 450 for awhile and it kept the temp, then lowered it to 325 for 1/2 hour and it kept the temp, yippee! It better keep working, because he's cooking a ham on Christmas!
Dec 09, 2010 | Hotpoint RGB745 Gas Kitchen Range
Oven will not hold temperature setting, what is
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Oven will not hold temperature setting, what is likely cause of problem?
replace the thermocouple located inside the oven cavity near the top,it is a copper or silver colored tube with an expanded end on it called the bulb,this component senses the heat and cycles the gas flow to the oven during heating
Mar 23, 2010 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas oven
This is an indication of low gas pressure to the oven. This condition may improve when other gas equipment is turned off and worsen when demands increase such as during cold periods where heating plants are running. Contact your local gas company to check pressures at the burners and adjust the incoming pressure to the oven accordingly.
If you found this helpful, please Vote!
Mar 03, 2008 | Hotpoint RGB745 Gas Kitchen Range
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Oven does not maintain temperature while cooking. Oven will come on and preheat as it should but then temperature drops while cooking and remains below preheat value. Every 15 minutes or so we set the...
Hello Michael Smith,
You MODEL number only came through as a
PARTIAL ... (so I filled in the rest (assuming USA)):
RGB745 ... wea2ww
Please note:
Accordingly... you will have to VERIFY the part.
Part and video guidance are available here:
Third item on the page "heat sensor"
http://www.appliancepartspros.com/parts-for-ge-rgb745wea2ww.html
Hope this helps...
Carnac the Magnificent
Aug 13, 2017 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
209 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
