2010 Seat Ibiza 1.4 Logo
j
joe donnelly Posted on Jan 24, 2014
Seat ibiza dash light come on when switch off and key removed
All dash lights come on when engine switch off and key removed the buzzer sounds once
Radu Nemtanu
Level 1:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Contributor 44 Answers
  • Posted on Feb 18, 2014
Radu Nemtanu
Contributor
Level 1:
Filmmaker:
New Friend:
Answers
44
Questions
0
Helped
12631
Points
91
You should stop the CD Player from button. The car has no problem but it notifies you that the Car Stereo was on.
4 Related Answers
gyver
  • 120 Answers
  • Posted on Feb 03, 2012
SOURCE: location of engine/vin number seat ibiza 94 model
8th digit of vin is the engine code
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jun 10, 2012
SOURCE: front lights /indicators wiring colours /diagram for 2001 seat ibiza
We do no have this make in the USA so have no info on it. Sorry
mpho skelem
  • 155 Answers
  • Posted on Oct 24, 2012
SOURCE: how do i fit a brake light switch on 2003 seat ibiza 1.2
underneath your stearing wheel loosen the covers there and on the brake pedal above it 2wards the stearing wheel you will see it allocated above the pedal loosen the lock(nut) unplug the connected switch then screw it open an thats it
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Dec 08, 2012
SOURCE: ABS light on, seat ibiza 05
First I suggest scanned the ABS module in order to know what fault code is stored there. Note it and send us for other details.
Good luck.
2answers
My seat Ibiza wont start its just turning over and theres nothing lighting up on the dash
You can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
Seat ibiza problems
don't worry be happy . start to worry when it causes you a problem
How do i fit a brake light switch on 2003 seat ibiza 1.2
I also have 98 neon with "door ajar" light and buzzer staying on but ONLY when all doors are closed. key doesnt evan have to be in ignition! also the dome light works perfect with the door and light switch...
sounds like their is a short in the wiring to the dome light and buzzer... i know you don't want to hear that... if it is grounded somewhere that is why it quits when you remove the bulb... possible wire caught behind the dash when you put it back together... if so that would cause the ground...
25helpful
2answers
How to reset service light on a 58 plate Seat Ibiza. Car has had full service and was not prepared to pay Seat dealer double but what they tell me is its a two second job, but will not tell me how to do...
Dealer would simply reset using diagnostic and charge you for it
Here is manual reset
Switch ignition off
Press and hold trip button left off speedo
Switch ignition on
Service will appear in display
Release trip button
Turn trip button to right untill [-] appears
Release trip button
Switch ignition off
2answers
Shorting wiring in dash
check along bottom edge of dash cover for screws, sometimes there are a few at the top as well...generally once they are removed the dash face will pop off with moderate pulling. Once off, you can access the light switch easily. (you may need to remove the lower cover to locate dash screws)
1991 mercedes benz 300ce. When I start the car and buckle the seat belt or belts the warning buzzer comes on and off. I don't know if it is a seat belt problem or an ignition problem. I only have the car...
on the driver,s side under dash there is an audible relay called a seatbelt warnung relay. I would recommend replacing it because by just unplugging it you may experience interior lighting issues. It is a very common problem with that era of mercedes. If you remove the under dash you will be able to locate it by sound with the key on. Unplug it with the key off.
1helpful
Light warning buzzer constantly on
Have you checked that the headlight switch is in the right position? Are the headlights or parking lights still on when the key is removed?
If so, then rotate the lamp switch to the correct position and the buzzer will go off. Headlights and parking lights are not controlled through the key circuits.
Lights on buzzer does not work
does your interior light and door light work when the door is open??.the lock mechanism has a micro switch that signifies when the door is open if this dont work niether will the buzzer...its a sound generated by the dash panel insert there is no sepperate buzzer.
Top Seat Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Jose Ramirez
Are you a Seat Expert? Answer questions, earn points and help others
