Question about IBM Infoprint 6700 R40 Printer
Labels unexpectedly stop printing half way through a job
Hi, I am using dLabel to produce barcoded labels generated from an AS400 then downloaded to a PC in a .csv file. dLabel senses the new occurence of the file and starts to print the labels on a Ricoh IBM6700 Infoprint printer. However, sometimes the print run starts, some labels are produced and then the printer stops unexpectedly. Looking at the printer properties shows that file printing is in progress but it just seems to 'hang'.
We also have a label winder at the end of the printer which, when labels are printed, rolls them onto a constantly winding reel. I was wondering if the winder is pulling the labels through too quickly and somehow the printer senses this thus causing the printing to stop. Have you known this to happen before ?
It doesn't matter on the size of the job either, we have printed jobs with over a thousand labels without problem, and yet the problem can occur midway between a much shorter run of say, 120 labels. The printer is connected to the pc via a USB cable.
Located winder further away from printer. Set winder to lowest possible speed setting. Thoroughly cleaned printer to remove any trace of label residue near print head and label cutter (sticky labels with pre-cut patterns are being used). No more problems reported. Will continue to monitor.
Posted on Jun 03, 2009
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
Tip
How do I adjust Barcode on the price tickets?
<p> <p> <p>Bar codes are created using the software to generate bar code and printed on price tags with bar code printers. Tickets barcode typically contain product information and pricing, but there are times when prices should be adjusted to produce a product more salable. Establish a barcode on a price tag, generating a new image of the barcode using a computer, print the barcode image and paste the image printed on the sticker price. <br /> <p><br /> <p>1. A site of a software program that allows you to create an image of the barcode (see Resources) to download. <br /> <p><br /> <p>2. See the homepage of the site and watch the program interface. Choose the type of barcode you want to generate from the list displayed. Enter the information you want to encode the space provided. Click "Generate barcodes" to create barcode images. See the image and right click on it to a drop-down menu to display. Click "Save image as" the image of the barcode on your local computer store. <br /> <p><br /> <p>3. Place a sheet of paper label on the computer printer. Open the folder where the image of the barcode. Right-click on the image of the barcode that you saved and click on "Print" from the menu bar to print. <br /> <p><br /> <p>4. Cut the bar code printed on the price tag to match, and stick it in the bar code on the old price. Scan the barcode with a barcode scanner and check the data sent to your computer. <br />
on Jun 26, 2011 | Computers & Internet
How do we embed into a Windows report, commands for a Tec B472
Hi Gilles483,
If you want to use a printer in windows, create a Generic text printer in the correct port and send the commands.
Nov 19, 2009 | Toshiba TEC B-472 Thermal Label Printer
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF...
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Nov 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra S4M Lable Printer Not Scanning
You might want to check the barcode ratio, bar width, printer speed and printer darkness. I am assuming that you are creating the barcode in some sort of label design package, correct? You either need wider bars, or make sure you have enough quiet zone on both sides of the barcode, so shrinking it might be the solution as well.
Apr 12, 2009 | Zebra S4M Thermal Label Printer
Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Jan 21, 2009 | Datamax M-4208 Thermal Label Printer
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Prints half the label.
Try reloading the forms from the AS400 by restarting the program. That should get it to work.
Jul 03, 2008 | Zebra 105SL Thermal Label Printer
Barcodes print too long
This is defendant on the program you use to print labels with. The printer responds to either a print job sent to the driver (like a standard windows printer). Or you can send an EPL program to the printer in order to use internal barcode generating features of the printer. The dimensions of the barcode are controlled via the EPL script. See the EPL programming guide avaialble on Zebra's website for more info.
Feb 27, 2008 | Zebra Eltron LP 2824 Thermal Printer
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
IBM Infoprint 6700 R40 Printer Logo
352 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
