Question about Hotpoint WF430 Front Load Washer
Wont drain and cant find filter
HotpointWF340
  • blueextc3221
    blueextc3221 May 11, 2010
    strainer is on the suction side of the pump. You must disconnect the piping to see it. It is inside.
    Problem Solver:
  • 12 Answers
Diconnect from mains ... remove back porthole panel ... look in you will see a black sump hose connected to bottom of drum by a band release the band and you will see the filter most likely with a sock in place blocking the whole sump
Posted on Sep 15, 2009
Where is front loader pump located, washer wont drain water, cleaned the filter ,want 2 look at pump 2 c if its good, cant find it
You simply take the 3 screws out from under the front lip. AND THE PUMP IS SITTING RIGHT THERE IN FRONT OF YOU SHOULD LOOK LIKE THIS
put a cake pan under the lip of the drain and unscrew the filter to take out the stinky water. Once it won't unscrew anymore pull the filter out and clean. OR PULL THE ENTIRE PUMP OUT TO PERFORM A INSPECTION OF THE PUMP
Nov 14, 2010 | GE WCVH6260F Front Load Washer
Our Electrolux front loadeing washer wont drain, and now it wont unlock! clothes are sitting in water and we cant open the door to get them out. Oh yeah...its giving us an E-21 error code. No...
You will have to get the water out,down by the filter at bottom lhs see if there is a small rubber hose next to filter if there is it should pull out so far then you can remove the small plug on end to drain into a container.If no hose down then try putting the drain hose down to floor level into a bucket or out of an exit door to syphon out water.Or get machine filter by an exit door and release the filter plug and let water drain out.E21 means that there is either some blockage in the pump or the drain pipe may be kinked or blocked.
Apr 19, 2010 | Electrolux EW1000i Front Load Washer
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
Cant get truck to stay running
did you try the fuel filter
May 20, 2009 | 2000 GMC Sierra
Wont drain water
inside hose at back ,take back lower panel off black hose filter inside.
Dec 19, 2008 | Hotpoint WMA48 Front Load Washer
Cant drain and cant open the door
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Jun 26, 2008 | Creda W100FW Front Load Washer
Washing machine wont drain
0872465395 Ire no charge
Dec 29, 2007 | Washing Machines
Hotpoint WF430 Front Load Washer Logo
128 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
