Question about NAD C352 2-Channel Amplifier
Connecting an outdoor MP3 player to an NAD C352 Amp
I want to try and use an NAD amp for dual internal and external use. I thought I could just set up an MP3 connection outdoors and somehow connect to the amp indoors then run speaker cable to outdoor speakers. Does anyone know if this is possible? cheers
  • 83 Answers
You could get a bluetooth dock and cables or just get a saeltech bluetooth speaker and run it off your computer .It will let you run your i tunes or media player and go thru your playlist or artist songlisting can also be operated remotely on the speaker unit ! Volume And tracks!!! swamp ratt!!! AAEE!!!!
Posted on Jul 21, 2009
What does "amp error" mean?
If your sub is connected to a separate amplifier, the internal amplifiers of the receiver would be at fault.
Aug 06, 2016 | Pioneer DEH150MP CD/MP3 Car Stereo Radio...
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
HOW CAN I TURN ON THE AUX IMPUT OF A Pioneer DVH-P7000 Stereo Receiver & DVD Player In Dash
Look carefully in the front panel for the source button- input. after connecting the RCA jacks input at the rear with a source, select this , do not put in the cd when you are trying out as it might go to the default setting of detecting the cd.
Hope you get this right.Good day
Jul 07, 2010 | Pioneer DVH-P5000MP - Car Audio DVD/CD/MP3...
Connecting NAD 2600a amp.
Never connect incompatible connections. Speaker outputs are for speaker inputs. Period.
The various inputs on this or most any amp are for Line Level signal with the exception of anything explicitly labeled "PHONO" as that would be for a non-preamplified turntable ONLY.
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used in the (assumed) preamplifier that fed this amp.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use the Lab In's UNLESS you have a turntable source.
Aug 22, 2009 | NAD Audio Players & Recorders
NAD C352 turns on but no sound
The first and easiest things would be to check all connections.
Speaker wires
RCA Cables !!
If you are getting a green light you are getting proper power and ground connection.
Other than that the other possibility's would be internal components, capacitors ect.
I would be willing to bet something has come jarred loose. Post back after you have checked and double checked all connections.
Aug 12, 2009 | American Pro VS-2043 Car Audio Amplifier
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
Pioneer indash stereo/cd player DEH-7500MP,no internal amp output
some cars have internal amps for the speakers try connecting the remote wire it's the blue wire with a little white on it worked in my moms van.. if that does not work try testing it with a speaker from your house
Mar 31, 2009 | Pioneer DEH-P7500MP CD Player
Amp c352 TI 1515456 failure
It sounds like yo shorted the speaker wires together for a short time and smoked the output section of the amp. The amber light is an indication that the amp is in protect mode. If you attempt to power up the amp and still have the amber light even with all speaker wires disconnected, the amp needs repair. The output transistors for that side will need to be replaced.
Dan
Mar 05, 2009 | NAD C352 2-Channel Amplifier
As mp3 player
An MP3 player is a solid piece of memory and an interface with a small amplifier. As such it is prone to fail after a while. You can try connecting it to a computer and see if you can format it or use a program like recuva to attempt to resuscitate it. However all may be lost.
Dec 05, 2017 | Audio Players & Recorders
NAD C352 2-Channel Amplifier Logo
193 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
