Question about Fuji FinePix S9000 Zoom Digital Camera
Finepix S9100 humming type motor noise
When ever I turn the camera on there is a motor type noise that does not stop. Almost sounds like the auto focus trying to run all the time.  Just got the camera used so I do not know what normal is for this camera.  All seems to work fine however. Any input?
  • 3 Answers
There is a setting on the left side of the camera- you have it set to constantly focus. I had the same problem
Posted on Jan 04, 2008
  • tigerob Jan 04, 2008
    addendum: the auto focus switch (AF) should be in the (S) position. Hope this helps.
  • Patnicha K
    Patnicha K Jan 27, 2018
    Thank you very much. I have the same problem.
A Fujifilm FinePix S9100 digital camera how to set it for High resolution pictures
Julia, download your manual from links below, to learn about all the options and setting for camera. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Support and Contact Center
Manuals HS SL Pro Series
FujiFilm FinePix FinePix S9600 Owner Manual
Jul 28, 2016 | FUJIFILM FinePix S1800 Digital Camera
How to fix my camera
Without having someone inspect the camera in person, it sounds as though a fault/defect has developed with the lens focus mechanism...that's about the only thing on this camera that's likely to make such a noise.
The first thing I would check is any focus options you have set in the menu. For example, is the camera set to continuous focus? That could keep the lens motor going constantly. If available, see if you have an option for spot focus or manual focus and if so, try setting it...that should, in theory, turn off the focus mechanism (and eliminate the noise).
If that solution don't help, unfortunately it may simply be time to replace the camera. The Finepix S3000 is an older 3.2 mp camera, which by today's standards is something of a dinosaur. Used, they're only worth $50 or less (I've seen a couple for as little as $15), so they're not really worth much effort at repair. Fuji makes some fine cameras, however like so many modern electronic devices today, they're simply not designed for longevity.
Mar 23, 2016 | Fuji FinePix S3000 Digital Camera
The paddle on my kitchenaid won't turn. It just makes a humming noise. Any suggestions?
Is the humming noise the sound of the motor straining to turn without moving (it won't last very long like that) or the sound of the motor turning but not operating the paddle?
Dec 21, 2014 | KitchenAid Food Mixers
Is there anyway to reset my s9100 to its default settings? I dont know what I've done but almost all of my photo's are turning out blurred.
You could go into the menu and find "reset" but, you should try some experiments first. Set the camera on a tripod or firm surface and take a couple of shots. Are they better? If so, you need to examine your shooting technique.
Jul 14, 2010 | Fuji FinePix S9100 Digital Camera
HUM NOISE OCCURES WHEN TURNING KNOB TO LEFT BEFORE PUSHING KNOB TO START- STOPS WHEN POINTING TO OFF POSITION - MODEL GYC4000AWW . DRUM DOES NOT TURN
it sounds like you have a bad motor and door switch. the unit should not run unless you push a start button. the humming noise is the motor. either something is blocking it or your motor is bad,
Oct 12, 2009 | Magic Chef CYG2000AWW Gas Dryer
Fuji s9100 Blurred view in the viewfinder but reads okl on lcd?
Look on the left side of the viewfinder - there's a small dial which you can rotate to adjust the viewfinder. I hope that's the problem. If not, please let me know, it's just that the problem description is quite poor.
Tom
Aug 01, 2009 | Fuji FinePix S9100 Digital Camera
Bought used fuji s9100, images are too blu and light??
go to the main menu setting and reset all to original it should take out the custom setting that have been stored in it
Jul 02, 2009 | Fuji FinePix S9100 Digital Camera
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Open Questions:
Fuji FinePix S9000 Zoom Digital Camera Logo
176 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
