Question about Acer TravelMate 4000 Notebook
Booting: On switch does not glow green light
My laptop does not boot. The on button seems to have a loose connection. Once pressed, the green light glows for fraction of a second and then gets off. What to do?
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
I once booted up the notebook (N90S) and forgot to plug in a usb, so i shut it off by pressing the on/off button again (it was booting up at that time). Once it turned off, i wanted to boot it up again...
You may have put it into hibernate or sleep mode. Sometimes a key press or mouse movement will wake them up. Other times you have to resort to the straightened paper clip pressing on the hidden reset button. Get your manual out and see if there is a manual reset button you can use to reset the machine. If not, remove the battery if you can and let the machine 'forget' what it was doing. Wait 10-15 minutes before re-installing the battery pack and trying to start it up again.
tom
Oct 11, 2010 | Computers & Internet
CRFATSMAN opener - Problem when closing only
It sounds like you have a loose connection. Pull the logic board and check for bad connections especially around the small transformer.
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Turning on but remains blank screen
it may happen that your extetnal (VGA Display) is enabled, this will disable your LCD Display.
just press Fn key and look function keys where monitor symbol is drawn ( that is F7 or F8 key. (turn on laptop then press Fn + F8/F7)
Aug 20, 2009 | HP Pavilion tx1000z Notebook
My HP laptop is not booting all of a sudden. Today morning i performed a forceful shutdown of my laptop after which it has stopped booting. On pressing the power on button, all the blue LED glows but the...
Try tapping on F11 after you turn the laptop on, and see if it will go into the recovery mode. If it does, you are in luck, and can choose how you want to do the recovery.
If it does not, you can order a set of recovery disks from HP for about $15us which includes shipping costs. Or, you can load any retail version operating system, and download/install device drivers from http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839164&taskId=135&prodTypeId=321957&prodSeriesId=1839143&lang=en&cc=us&submit=Go%20»
Good luck, and please rate my response.
Thank you
Mar 15, 2009 | HP Compaq nx6310 Notebook
Lenovo booting problem
so u;re saying that the BIOS tests are taking 10 minutes ?! Usually that happenes when the computer shutes down brutally (after power surges, by removing the battery ... by forced shut down). Try doing a BIOS update, and also set it so it will skip some tests or not to do through testing ....
Aug 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Not booting Up when power on
try setting your BIOS to default as it seems like someone or something has changed settings
Jul 25, 2008 | ASUS P5S800-VM Motherboard
My ibm thinkpad booting and hanging fault
Try this... to see if your video card is bad...
Connect your laptop to an external monitor and press the Function key plus F5 on the laptop... if your OS shows up on the monitor screen, then you have a bad video card...
If its not the video, Bad Ram might be the cause.
And worst case.. Need Motherboard replaced...
Jun 09, 2008 | IBM ThinkPad T42 Notebook
NEC Versa s970
when the bluetooth and wlan light are off press the wireless button three times and wait a sec and it will work. thats what nec told me
Apr 16, 2008 | NEC Versa LX Notebook
Acer TravelMate 4000 Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
