Question about D-Link AirPremier DWL-1700AP 802.11b Wireless Access Point
How to i get to reset my unit as i dont know its ip address ans also dont have the MIL-C-5015 RS232 Console Port Cable
How do i get to reset my DWL-1700AP as i dont know its IP address. Thanks
  • 628 Answers
Reset router to default settings normally is done on the device, where there is a tiny hole for u to insert a pin inside.
Posted on Jun 02, 2009
  • 3,267 Answers
You must be intending to use skype or a similar service provider. For the first time,Use a pc, connect the wireless device, log in to to skype and select autoconnect. Once configured it will work without any PC via wireless connection with the internet to communicate...sodeep
I cannot connect using serial console port (no signal / data out of serial console port). I don't have IP address of the DS4100B. I don't have its password... How can I reset it to factory default?
I am assuming you will still need console connection to do a password recovery.. however, here is the link to one password recovery doc that may help.
May 10, 2016 | EMC DS-4100B 32 Port 4Gb SAN Switch
I have a xbox 360 tryin to get on the xbox live but wont let me
1. go into your modem through internet browser and type in ip address...(type find my ip address in google if you dont know it).
2. Enter username/password...("admin" is usually the username/password by default...if you cant get in, there is a reset button on your modem...very small...might need a pin to poke inside...PUSH AND HOLD IN FOR 30SECONDS and repeat step 1 and carry on from there).
3. Find these settings in the modem: -LOCAL NETWORK / UPNP......enable it -DMZ HOST.......type in your ip address you typed in to get into your modem....(you might not have DMZ which is even better so don't worry about it).
-VIRTUAL SERVERS/PORTFORWARDING.....type in the following:select custom service or name and type in i.e XBOX360 AND TYPE THESE IN:Port start 3074 port end 3074 and TCP protocolPort start 27014 port end 27050 and TCP protocolPort start 3074 port end 3074 and UDP protocolPort start 3478 port end 4380 and UDP protocolPort start 27000 port end 27030 and UDP protocol
5. reboot modem.
6. Go in XBOX network settings and in basic settings manually type an ip address that is within your dhcp range...( dont worry what this means just follow the example) to your normal ip address i.e if your ip address is 10.1.1.1 then you would use 10.1.1.100 etc, 255.255.255.0 in subnet mask and your main ip address in gateway.
7. DNS settings should be automatic.
8. reboot XBOX you are ready to go.
HOPEFULLY :P
TEEMAN
Nov 12, 2011 | Microsoft Xbox 360 Console
Have secondhand gsm7312 and don't know username or password. How can I factory reset this unit? There is no reset button and I can't enter menus via console cable as it asks for username (not the...
Netgear FSM (and GSM) switches have an RS232 serial console port. Connect to that using Hyperterm, PuTTY, Xterm etc. at 9600-8-N-1, and power up the switch. Early in the boot process, it will give you a choice of normal operation, or the boot menu. Select the boot menu before the time runs out (usually a couple seconds), and one of the options will be to reset the switch configuration, including the password.
Jul 26, 2011 | NetGear ProSafe GSM7312 Ethernet Switch...
Cannot log into the SMC8024l2 switch via ethernet or console and after resetting to factory defaults still cannot ping the device at the default IP Address or the IP address it was set up on.
Looks to me like they never implemented the serial port. The used unit I just obtained has no signal on the serial console pins and no SMC documentation beyond plugging it in appears to exist. Likewise with TELNET access.
However you can reset the switch to factory defaults with the following procedure from a pop-up window off the login page. It worked for me.
If you have forgotten the administration password you can return the Switch to its factory default state by doing the following:
1) Remove the power cord from the back of the Switch.
2) Remove all cables from the front-panel ports.
3) Connect port 1 to port 2, on the front panel, using a standard network cable.
4) Reconnect the power cord to the rear of the Switch.
5) Wait at least 40 seconds before disconnecting port 1 from port 2.
After completing this procedure, the password will be 'smcadmin' and the network address will be returned to the default; 192.168.2.10/24.
Apr 02, 2011 | SMC EZ Switch SMC-8024L2 24-Port Gigabit
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Apr 17, 2009 | Aironet BR500
    I cant reset my senao eoc3610
    1 ) Check if IP address is the correct address of your Gateway.
    Check if you can ping.
    Be sure you have your Java enabled
    Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
    Be sure to remove any Java protection from your Browser.
    Check with user manual if IP address requires also a specific port number ( 8080 or other).
    Be sure to Connect Router using Lan cable
    2) Change your PC IP setting to same subnet as your router
    Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
    3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
    Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
    Procurve 2626 installation
    You'll need to obtain a comms lead - connects into the console port of the switch then into an RS232 port on your laptop. Then, you will be able to connect using hyper terminal and you can give the switch an IP address, username, etc. Even a hard-reset won't allow you to configure an IP address as by default it needs to be configured through the lead. Will they not talk without being configured? If you just hard reset them, they should just behave as unmanaged switches.
    Aug 14, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
    My 3rd reply...
    Nat1147,
    Did you choose "obtain an ip address automativally" under properties in the network connections? If both pc's have the same ip address, then that would create a conflict.
    run ipconfig on both pc's and verify the ip address for both pc and that the ip address starts with 192.xxx.xxx.xxx .
    An addition, make sure the ethernet cable from the modem is plugged into the internet port on the router. If you dont have the ethernet cable plugged into the proper port on the router than that too can casue conflict.
    Hope this helps and good luck.
    Jul 27, 2008 | Linksys Wireless-G Broadband Router
    How to assign ip to the printer
    Using the LPT port is not the same as using the network port. The LPT port does not utulise an IP address.
    Plug in a network cable to network port and the printer wil usually aquire an ip address via DHCP.
    I repeat the LPT port is not a network port and cant initialise an ip address
    May 23, 2008 | Brother HL 5250DN Laser Printer
    D-Link AirPremier DWL-1700AP 802.11b Wireless Access Point Logo
    173 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
