Question about HP 1010 Plain Paper Inkjet Fax
Trying to get my fax printer to work
I got it from a local store and no disk came with it . it is used. my computer shows a list of hps to choose but not mine . how can i substitute the up load information so i can get it to work. A default input would be nice i guess?
  • Anonymous May 11, 2010
    If this is the proper model number (hp 1010), it's just a fax -not a printer. Please clarify
  • 37 Answers
Do a google search for this product. I found the specs on this machine. hp fax 1010. In the specifications it does not have print option.
looks like this machine is a stand alone fax and can be used as a copier. I do not believe that it can be connected to your computer.
Posted on Jun 08, 2009
Not printing from a mac
Use one of the following methods to print, depending on how the printer is connected to the computer. hpweb_1-2_minus.gif Method one: Printing from a USB printer
  1. Make sure your printer is turned on and connected.
  2. Open a document to print, and then choose File > Print .
    NOTE: You can also go directly to System Preferences > Print & Fax .
  3. From the Printer pop-up menu, choose your printer. If you do not see your printer listed, choose Add Printer , and then click More Printers .
  4. In the Name column, select your printer, and then click Add .
hpweb_1-2_minus.gif Method two: Printing from a network printer You can connect to HP printers on your local network (wireless and Ethernet) using Bonjour or IP, as well as shared printers connected to an Apple Airport base station.
NOTE: Apple does not support AppleTalk in Mac OS X 10.6.
  1. Choose File > Print .
  2. From the Printer pop-up menu, choose your printer. A dialog appears, listing any Bonjour printers on your local network. It may take a minute or two for your printer to appear.
    NOTE: Your printer may also be listed in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu. Printers that are turned on and connected to the local network (wireless and Ethernet) should appear as Bonjour devices.
  4. Select your device from the list, and then click Add to create the HP printer queue for your HP Photosmart, Officejet, or Deskjet All-in-One printer.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays or a duplex unit. If it cannot, a dialog appears that lets you specify them. To enable full functionality, make sure the settings in that dialog accurately reflect the installed options.
The latest HP Utility is included in Mac OS X 10.6.
Method one: Open the HP Utility from System Preferences
  2. From the Apple menu, choose System Preferences .
  3. Click Print & Fax .
  4. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  5. Click Options and Supplies .
  6. Click the Utility tab at the top of the window, and then click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Method two: Alternative The HP Utility can also be launched from the printer icon in the dock to open the Printer Browser window.
  1. Double-click the printer icon. The Printer Browser window opens.
  2. Click Printer Setup in the toolbar.
  3. Click the Utility tab.
  4. Click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Jan 18, 2011 | HP Officejet 6310 All-In-One InkJet...
Tip
How to connect the Printer to a network ?
Connecting the USB Printer to network
1) Right click on My computer
2) Click on Properties
3) Click on Computer Name
4) Click on Change (where it says "To rename this computer or Join a domain, Click Change")
5) Give Name to your Work Group
"Type the some Name in the BOX"
6) Click OK and Restart the Computer
** NOW THIS COMPUTER IS A PART OF WORK GROUP **
(settings on Main Computer where the Printer is installed)
7) Now we can share whatever you wana share
8) Open control Panel
9) Open Printer and Faxes right
10) Right click on the Printer Icon and click on Properties
11) Click on Sharing
12) Click on share this printer and *Name the Printer if you want share
13) Click on Apply now this Printer is in Network
Network the Second Computer
13) Go to each computer
1) Click on Start - control panel -
2) Click on Printers and Faxes
3) Click on Add a Printer
4) It will show Welcome to Add Printer Wizard
5) Click on Next
6) Select "A network printer, or a printer attached to another computer
7) Select browse for a Printer and HIT NEXT
8) It will show you the WORK GROUP and when you hit on it it will show you the Printer
9) Click on Next and OK
Its Done the Printer is Shared and you can take a print out.
Note : The Main Computer should On in order to take Print-out
Hope this will help you connecting your USB printer to the Home Network
or IF YOU HAVE THE NETWORK PRINTER check the following steps
Adding a new network printer
1) Click on Start
2) Click on Printer and Faxes
3) From the left side of the window - click on Add a Printer
4) It will Pop up a new Screen (Add Printer Wizard Window
5) Click on Next
6) Select Local Printer
and Uncheck Automatically Detect and install my plug and play printer
7) Click on Next
8) Click the DROP-DOWN menu next to Use the following port
and if the Printer Queue is listed,select it and click NEXT
***IF it is not listed in the Menu,
Choose Create a new port
from the Type of the Port list - select Standard TCP/IP Port. Click Next
In the Add Standard TCP/IP Printer Port Wizard window, click Next.
In the Printer Name or IP Address field,
- Type the queue name of your printer and the Port Name field will be automatically filled in
Click Next
Click Finish
IF Required Install the Printer Drivers using the Disk
9) If you are asked whether you want to keep an existing driver, select Replace existing driver, then click Next.
10) In the Printer name field, type the printer's queue name, model name, location and double-sided or single-sided. If this is the printer you will be using most often, select Yes to use this printer as your default printer; otherwise, select No. Click Next.
11) If you are asked whether you wish to share the printer, select Do not share this printer. Click Next.
12) When you are asked whether to print a test page, select No
13) Click Next.
14) Click Finish.
Note : You may have to wait a few seconds for the Add Printer Wizard window to disappear and it may appear frozen.
If you receive a message that a Microsoft digital signature was not found, click Yes to continue the installation.
TEST THE PRINT
To check if the printer is working correctly, go to Start > Printers and Faxes. Right-click on the newly created printer, select Properties and then click on the button for Print Test Page.
on Jan 22, 2010 | Office Equipment & Supplies
My computer wont set up my printer
Turn on the printer and the computer. Connect the printer's cable to the printer and the computer.
Click on the "Add Hardware" wizard, if it comes up automatically. If not, click on "Start," then "Control Panel" and then "Printers" or "Faxes and Printers." Click on "Add Printer" on the left side of the window.
Choose the manufacturer and model number for your printer from the list in the installation wizard. If your printer is not on the list, you can click on the "Have Disk" link and insert the printer's installation CD. If you do not have the CD, you can download the software on the manufacturer's website.
Select "Local Printer Attached" and wait as the computer connects to the printer.
Restart the computer once you are done installing the printer's software. The installation software may ask you to restart the computer. If not, initiate a restart yourself.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 14, 2011 | Epson Office Equipment & Supplies
I cannot connect my computer with a printer
The solution to connect or add the printer in your computer/PC here are the step shown below:
  1. Go into Control Panel
  2. Open or click on Printers and faxes icon.
  3. Click on File>select Add printer from the menu bar
  4. Click on Add a Local Printer
  5. Choose Create a New Port with type of port remaining Local Port, then click Next
  6. In the Port Name box type the path to the printer you wish to install to and Click Ok
  7. In the Install screen, select your printer from the list or choose Have Disk and find the location of the printer drivers on the computer then click Next and then click Finish.
  8. Now you'll see the installed in the Printers window.
  9. Right-click on the printer and click Properties
  10. On the General tab, click Print Test Page to test the printer.
You should now be able to printer from to this networked printer with any problems.
good luck thanks
Aug 27, 2010 | Computers & Internet
I got a refurbished hp1730 computer. I have a
try downloading the driver for the printer from the mfg website and install it on the PC....
then configure the printer using the software that was installed...
let me know....if u have any issue...
we can fix it...if u cant after doing the above...
Dec 20, 2009 | Computers & Internet
I need to download driver for it
You can download is from http://www.retrevo.com/s/Panasonic-KX-P3124-Printers-review-manual/id/313bh332/t/1-2/
Sep 24, 2009 | Panasonic KX-P3124 Matrix Printer
Need hp deskjetf4288 software
HI Its better if you use the default printer drivers available in the computer.
go to printers and faxes --->choose add a local printer--->make sure you check the right port,
for HP Deskjet it should either be DOT4 and most likely the USB0001 port--->when you get the manufacturers list---->choose HP and in the right pane look for Hp Deskjet 550c,
this works as the default printing drivers and you shouldn't face any issues as far as printing from the computer is concerned,
for further clarifications you may reply here.
Jun 09, 2009 | Office Equipment & Supplies
Problems installing a printer
what is your operating system? If you have windows XP or Vista, you dont need to download anything from Epson. Just go to your start menu and look for control panel. In control panel, open "printers and faxes" or "printers and other hardware" then "printers and faxes". Once you are in "printers and faxes" click Add Printer...
An "add printer wizard" will appear in a new window, click next...
On the next screen, choose local printer. And make sure that the option "Automatically detect and install..." is selected. It will start searching... If the wizard did not find the printer, it will come up with a list of manufacturers... From this list choose EPSON and a list on the right side will show you the model names. Look for the LX-300 on the list, it should be there! Install it and you're done... The driver is already included in the windows operating system. You dont need the disc if you have Windows Xp or Vista....
Jun 27, 2008 | Epson LX-300 Matrix Printer
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
NEC SuperScript 870 Printer
First open your Control Panel and click Printers. Now click “Add a Printer”. Specify if you printer is Local (plugged in to your computer) or on the Network (plugged in to a different computer). We are assuming you have a Local printer.
Next specify the port. Usually you can just take the default here. Now you will be presented with a list of available printer drivers with manufacturers on the left and printer models on the right.
Under manufacturers choose “HP”. Then on the right scroll down and find the “HP LaserJet IIP”. It will probably show up just after the “Laserjet IIIP”. Click next and follow the instructions to complet installing your printer.
Aug 13, 2007 | NEC SuperScript 870 Laser Printer
HP 1010 Plain Paper Inkjet Fax Logo
61 people viewed this question
Seeker5211
Seeker5211
