Question about Brother DCP-7020 All-In-One Laser Printer
Black line in center on manual feed
Thi i ssimilar to an issue with the Brother MPC 7820n I had.  I can't remeber the resolution tho.
The drum and toner have been replaced, and we get this line in the center of the page ONLY on manual feed.  Print test pages are great quality.
Any direction would be gretaly appreciated !
  • Brother Master
  • 1,113 Answers
If you are getting marks on copies but not prints then it is the small slit of glass prior to copy glass that is marked/dirty
Posted on Nov 16, 2007
We've tried 2 new toners in the Brother 7820n and still get the same error...Change Drum Soon. We've turned it off, slid the blue arrow to clean the drum wires, still won't work...please advise....
Open front cover where drum/toner goes in
Press "Options" key on control panel
LCD will display "Replace Drum 1. Yes 2. No"
Press 1 to reset drum
Close front cover
Nov 09, 2010 | Brother MFC-7820N All-In-One Laser Printer
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
I refiilled tho toner cartrage with a generic toner as i have bin doing for years,and it still says tonen life end. i know that in the past when i bought generic toner it came with instuctions how to reset...
Open the front cover of the machine, press the clear/back (or options) button. it will say replace drum? press *00 close the front cover
this will reset the toner cartridge for you.
Jul 01, 2010 | Brother MFC-7820N Printer
Prints a black streak whether I copy, or print, not dirty glass on Brother 7820N
Try cleaning the corona wire of the drum unit.
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother MFC-7820N Laser Printer
I have a 7820N. I put in a new drum in January and have printed a few hundred pages. Put in a new toner cartridge after i started getting lines and streaks on the paper. They come and go but are getting...
Hi There,
When you installed your new drum did you reset the drum by.
1 - Opening the front cover.
2 - Press the options button up on the panel.
3 - Press 1 to reset
4 - Close the front cover done.
If the issue persists after resetting your drum contact brother technical support you may have a defective drum unit.
Mar 03, 2010 | Brother MFC-7820N All-In-One Laser Printer
Brother printer that prints a black line down center
probably a bad drum cleaning blade, It's part of the drum unit
Feb 02, 2009 | Brother MFC-7820N Printer
Brother 7820N, printing image repeats?
have you tried changing the drum unit for a brother oem unoit and oem toner? generic toner and drum will always mess the machine up!!!!!!! good luck brother sr tech
Dec 22, 2008 | Brother MFC-7820N Printer
Black line down middle of page
Clean the inside of the printer with a soft rag, be gentle and get as much toner up as you can, also your toner carttridge may be empty or the crum may be bad, start with a fresh toner carttridge and clean the printer out where the cartridge sits.
Dec 13, 2008 | Brother MFC-7820N Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
227 people viewed this question
James Cagle
James Cagle
Jim Keysor
