Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Doesnt clean clothes
My whirlpool toploader doesnt turn clothes around its just shaking it and clothes come out dirty soap just stays on the clothes on top what can be the problem.
I have a solution...buy a better washer! Sorry. But with my heavily soiled work clothes i have to use the 'bulk setting' and use smaller loads, AND and a 5 gallon bucket of hot water in the wash cycle. The latch is broke now (probably from me constantly doing this) Will replace with an agitator or a front loader. But i think any water saving washers will not perform good on my particular clothes.
Posted on Sep 04, 2009
    Novelist:
  • 148 Answers
I have founf a website that is quite useful (My opinion only, and I'm sticking to it).
The website is well informed on appliances from what I've seen so far, especially Whitegoods.
It is http://www.appliancepartspros.com/ at this site you can go to a Repair Forum and or a Repair Blog and seep thru for an answer by typing some info into the Search field ther.
All the best now,
Bastian a Useful Site Hunter and Bookmarker.
Posted on Jun 02, 2009
Our Duet just doesn't clean very well anymore. There's soap residue in the clothes sometime, and the clothes don't always smell clean. Are there any filters to clean out? Is there a way to get it to use...
The drain is probably clogged and the dirty water is going back into the washer. This happened to us, and the clothes were getting grey and dirtier than when they were before being washed. Make sure the drain pipe drains well, check hoses and clean the machine.
Dec 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Soap residue
if you just have a soapy residue( bubles atop the clthing?? either your using way to much soap, or way to much of wrong soap.you need to use HE detergent specifically formulated for front loading amchins(low sudsing. or your having a cold water inlet problem set te hunit to cold/cold/ try running see if inded the machine fills
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dark dirty spots on some clothing items appears on every load.
what you are seeing is suds getting back onto the clothes. make sure you are using HE type soap and not using too much of it.
if you are seeing suds inside the unit, when it is running, then it will "re-deposite" dirty soap residues back onto the clothes.
you need to run a rinse and spin cycle or even a heavy duty cycle with hot water to rinse out any soap that is left in the unit.
not a major problem, just use it differently and it will be ok.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso Topload washer Won't aggitate correctly
Possibly a belt issue take the top cover off of the agitator and remove the bolt that holds it down. There will be gears inside if any of these parts are broken this will also cause it not to agitate. Let me know
Jan 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Can i adjust the water level on my Duet?
Sorry there is no way to adjust the water level. the washer decides how much water by how much clothes are in the washer .
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
CLEAN SOFTNER DISPENSER
It snaps in. No need to clean it as it cover the agitator cams or dogs.
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Load Washer WFW8300SW00 Problem: I am using HE detergent and using less than the recommended amount; however, there is always a small ***** of suds sitting on the seal when I open the...
If you have a water softener or very soft water, soap will suds up more than if your water is normal or hard, so you'll need to use less than recommended. Obviously soap breaks down the dirt, but the dirt also breaks down the soap, so if your clothes are not very dirty to start with, you'll need less soap than if they were more dirty. Soap can also be stored in laundry like towels and cleaning rags and when combined with the laundry soap will suds more. You can try raising the leveling legs in the front to tip the washer back. This will help the water drain back into the tub instead of pooling on the boot. You can also try using the 'extra rinse' option. Keep cutting back on how much soap you use until your laundry is not as clean as it should be. You might be surprised how little soap you can use!
Jul 21, 2008 | Whirlpool Washing Machines
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
184 people viewed this question
Dan Webster
Dan Webster
Sal De
