Question about Hoover 24 in. HD98E Built-in Dishwasher
Error 4 when i turn my hoover whisper, it runs for a couple of minutes then it starts beepinng and the light flashing E4, i no longer have the manual therfor i don't know what Error 4 means.
    President:
  • 1,197 Answers
Check out the following link... i think it will be useful for u...
http://www.fixya.com/support/t1213494-dishwasher_flashing_error_code
thank you good luck
Posted on Jun 02, 2009
Hi i just bought Electrolux Dishwasher ESF2433W When i first time turn it on, the "Normal" button light keep on flashing with beeping sound. According to the trouble shooting manual, it actually refer to...
If you just bought Dishwasher ESF2433W I suggest you contact an authorized service center because the appliance is under warranty..
E4 : if overflow micro-switch is act and keep for longer than 2 seconds, the E4 would occur. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown.
Sometimes defects are generated by incorrect transportation appliances so that should be taken into consideration.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
I just bought a 2003 Ford F150, and a warning chime goes off right after starting. Chimes 5 times, pause, and repeat 4 more times. There are no lights or codes displayed on the dash. It drives fine, but...
The warning chime of 5x5 is a sign that the SRS ( airbag ) light is burnt out, and there is an error with the SRS system.
Verify SRS ( airbag ) lamp operation, turn the key from off to run ( do not start ) the airbag lamp should illuminate. If not, it is burnt out. Need to pull the cluster and replace.
( thread at F150online.com on cluster removal in the how to forum - titled about changing cluster illumination color or installing a cluster overlay ).
Once you replace the SRS bulb, you will get a LFC ( light Flash Code ) of a 2 digit number.
Example :
flash flash flash flash { short pause } flash flash { longer pause } flash repeats the same for 5 times, the solid on.
This is an example of a LFC 4-2. Once you have the LFC start a new problem with the LFC and we can get that fixed after you get the bulb replaced.
Aug 23, 2011 | 2003 Ford F150 Regular Cab
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Hoover ultima code F-02 flashing
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Jul 17, 2009 | Washing Machines
Hoover dt999
E4 means that water is not discharging properly, check the hose, filters etc
Mar 30, 2008 | Hoover 24 in. DT999 Free-Standing...
Hoover 24 in. HD98E Built-in Dishwasher Logo
521 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
