Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Error codes 283 and 232 in received Faxes
I have a new HP M1522nf multifunction printer scanner and fax. It is networked and is also attached to a dedicated fax line. I have sent faxes from my personal fax machine to the HP M1522nf, fine. One person cannot send me a fax. I get the comm error 283. Several other people have said this has something to do with the Error Correction Mode (ECM)? I am also getting error code 232. Please help! I've got the same problem, with one person. He faxes and I receive an error code 283. He tries again and I reiceive an error code 232???
    President:
  • 1,197 Answers
Basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Posted on Jun 02, 2009
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
Aug 14, 2012 | HP PSC 2410 All-In-One InkJet Printer
Will the machine saying 101000 memory error message make you not receive the faxes that are trying to come in.?
This error is a bad chip on the toner cartridge. Replace your cartridge and your printer should be fine again.
Feb 16, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hello I ve got 2 hp M1522nf printer and they have the same message: err. scanner 5 Can't print anymore send faxes...Do anything.
Hello, The scanner is failing to initialize, this is a common problem with this printer. The printer will also randomly power itself down, Good news it can be repaired, Follow the link for more information.
M1522INFORMATION
Thanks
Nov 15, 2010 | HP LaserJet M1522nf Multifunction Printer...
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
After I scan documents with the M1522, it will not receive faxes
Hi dbraaten,
This sounds like there is a problem with the scanner assembly. Are you getting any error messages? Like scanner error 5? If so call hp tech support 1800 334 5144.
Al
Dec 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
I have a LaserJet M1522NF printer and it does not receive some faxes and gives me a error 79 message on the display screen? can some one tell me what this is? i usually have to turn it off and turn it back...
Hello KIM !
Try doing an NvRam (Hard reset)
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
Feb 25, 2009 | HP LaserJet M1522nf Multifunction Printer...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
3,276 people viewed this question
Seeker5211
Seeker5211
