Question about Philips 32PF9964 32 in. Television
Clicking power supply? wont turn on
Hello, the TV doesn't start anymore, it keeps clicking and clicking as if it is trying to turn on but stays clicking non stop.. that ths is actual TV, the box ( the controller I guess) starts and after about 20 seconds turns itself off . any idea please? I have a larger tv and it use to turn on after leaving it clicking for ages. But now it will never turn on. If I plug a computer into the VGA (blue computer plug) its stops clicking but still doesnt turn on. Any ideas? not sure the model no.
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 02, 2009
My phillips flat screen keeps clicking like its trying to turn on and wont stop clicking untill i unplug it from the back.. what am i up against ?
The tv power supply board is dead.The the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 19, 2010 | Philips Televison & Video
My philips 42PFP5332D/37 keeps making a clicking sound, it wont turn on, and like most other post i have read, the blue power light stays on, but nothing more..it just keeps clicking, its been doing this...
I had the same problem and it was the power supply board,but I replaced it myself and only spent about $140.00 for the part and 2 day shipping . It was easy just pull the back cover off and there are about 8 small screws that hold it on and like 6 connectors that's it. Also ShopJimmy.com was the place for parts on these T.V.'s.
Nov 07, 2009 | Philips 42PFP5332D 42 in. Plasma...
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Takes ages to turn on.Keeps clicking off.
If this is a plasma unit then it might be the power supply causing the problem, but more then likely its the system control module.
Oct 27, 2009 | Televison & Video
Samsung lcd wont turn on just keeps clicking
Check for swollen capacitors on the power supply board.Very common problem on samsung lcd tv's.
Aug 28, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Tv wil not turn on just keeps making a clicking noise
ur relay keep try hard to turn tv on that u hear clicking noise.
+5VDC is leaking! open back cover,check power supply board.
1000uF or 2200uF capacitor is popped open or leaky.replace with known top quality capacitor.do it ur self repair will save u $200.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
32PF9962 32''
Could be power supply failure
Mar 06, 2018 | Philips 32PF9964 32 in. Television
Philips 32PF9964 32 in. Television Logo
584 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
