Question about SMC 5PORT (711000089)
Adapter remove the adapter from you compuer and reinstall it. write down the procedure you follwed?
  • 47 Answers
??  Is there a question here?
Posted on Oct 27, 2007
My compuer crashed now i can"t get router to work
Reset the router.Here is how:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | Linksys Wireless-G WRT54G Router
Wen i conect my compuer only de power light comes on.day before i working normal and i switch off normal.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Toshiba Satellite 1805-S204 Notebook
When i open an folder my compuer always ask to
that means your system affected with virus. you can open it by choosing internet explorer from the list. Or you can choose the drive from drop down menu in address bar in my computer.You need to scan your system with anti-virus and remove autorun.inf virus.
Apr 24, 2010 | HP Pavilion dv9623cl Notebook
I have tried removing battery and reinstalling. i have reset with button and have used new ac adapter. I get power to laptop but all it will do is the power light blinks like in standby mode. it will not...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
Please get back with the results.
Mar 19, 2010 | HP Compaq Presario 2135US Notebook
The intel (R) adapters are not present in the computer
Intel adapters I am familiar with are integral to the mother board, which is not to say Intel doesn't make other types of adapters. Look at the device manager and if you find it there, remove the device and reboot.
If they are PCI based, physically remove them - boot - test your computer - shut down. Restart - reinstall the software. Shut down - reinstall the PCI device (or what ever Intel has told you to do with this NIC
Dec 15, 2009 | Computers & Internet
The HP officejet 5610 shows that it's offline, but it's all connected to the power and the usb cable is connected to my computer. What do i do?
assuming that u hv proper licensed n updated antivirus installed n working..
itz a typical deskjet problem..it'll probably not work with a re-installed os/driver or to any computer..!! the printer is probably defective..
1st download, install n run microsoft kb890830..uninstall n reinstall all the printer driver (follwing installation procedure)..see if anything changes..
do contact authorized hp service center immediately..
for more details contact ur system admin/vendor....
Oct 28, 2009 | HP Officejet 5610 All-In-One InkJet...
Need to unlock volume control Nano ipod Apple
Please follow these steps for unlocking your iPod;
Please plug in the I POD to the compuer using the USB cable as first, you have to enable showing hidden files and folders to do it;
Click start-> MY COMPUTER(On the compuer screen)
Go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders", click OK.
Now, plug your iPod to your computer. You will see your iPod in "My computer" as a removable drive. Open it by double clicking, go to "iPod_Control" folder ,then "Device" folder. You will see file named "_volumelocked", please delete it.
Eject your iPod. Then, restart your iPod, You can do this by holding down the center and menu button for at least 5-6 seconds. Your iPod screen will go black and then you will see a Apple logo.
After reboot, you will have no limitations about sound.
Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Please rate me if you are happy with the level of support provided in regards to your query.
Sep 15, 2009 | Apple iPod nano
My computer doesnt reconise my belkin adapter??
well try that same adapter in any other compuer if the 2nd comp isn`t able to recognise the adapter then the adapter may be faulty but if does then you have to disable the firewall and antivirus software on your computer because it may blocking the adapter.
hope that will help you.
Jun 08, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
Oil on sprark plugs
  1. Disconnect the negative battery terminal.
  2. Remove the valve cover, using the proper procedures.
  3. Remove the camshaft, shims and rockers, if equipped, using the proper procedures.
  4. Remove the spark plugs.
  5. Rotate the engine to Top Dead Center (TDC) for each cylinder's seals that are being replaced; e.g., if replacing the No. 2 cylinder valve seals, have the No. 2 cylinder at TDC. Use a coat hanger put down into the cylinder to determine when it is at TDC.
  6. Attach a fixture at the flywheel or the front of the engine to prevent the engine from rotating. Make sure the fixture damages no components.
  7. Thread an adapter into the spark plug holes that can be hooked up to a shop compressor air hose.
  8. Apply 90 psi of shop compressor air to the adapter hose. This is done to keep the valves from dropping down into the cylinder when the valve springs are removed.
CAUTIONTo avoid personal injury, wear eye and ear protection. Keep hands and clothing away from engine parts that rotate, in case the engine does rotate from the cylinder air pressure.
  1. With the cylinder under pressure, remove the valve spring retainer and the spring, using a spring compressor tool. Hitting the spring retainer with a soft hammer may help loosen the valve keepers, if the keeper will not move downward when trying to compress the spring.
  2. With the valve spring removed, remove the oil seal.
To Install:
  1. Install a new seal, using Toyota Special Service Tool (SST) 09201-41020, or equivalent.
  2. Reinstall the valve springs (See Valves).
  3. Release the air pressure and reverse the removal procedures to complete installation.
  4. Connect the negative battery terminal, start the engine and check for leaks.
0900c15280046373.jpgFig. 1 Removing the valve sealsCelica 0900c15280046378.jpgFig. 2 Intake and exhaust valve sealsCelica 0900c15280046379.jpgFig. 3 Installing the valve sealsCelicaWith Cylinder Head Off Engine
  2. Remove the cylinder head, using the proper procedures.
  3. Remove the valve and spring (See Valves).
  4. Remove the oil seal.
To Install:
  2. Reinstall the removed components to complete installation.
  3. Connect the negative battery terminal, start the engine and check for leaks.
Aug 25, 2008 | 1990 Toyota Celica
H P Pavillion dv 9700, problem : screen is black like in sleep mode. I shut off, removed battery reinstalled battery, turned back on could hear the windows sound coming on but screen is still...
Try this -- it is called a Power Drain Procedure -- HP technical support helped me with this --
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Jul 08, 2008 | Computers & Internet
SMC 5PORT (711000089) Logo
32 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Mark Gough
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
