Question about Nokia Cell Phones
Hand set does not get ON.some time there will be some display but no start ups
  • 105 Answers
Plz change your hand set
Posted on Jun 03, 2009
How do i set both times i cant fugure out how to sync the digital to the clock
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right). The "B" button is at the 10 o'clock position (upper left) The "C" button is at the 8 o'clock position (lower left) The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET 1. Pull the "M" button out to the setting position. 2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING 1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window. 2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise. 3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24". 4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons. 5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete. 6. Reset the time, calendar and other modes.
To set the time. Note that changing the time in any of the cities will automatically update the time for all the cities. 1. Press the "M" button to move the mode hand to (TME) 2. Press either the "A" or "C" button to move to the desired city. 3. Pull the "M" button out to the setting position. 4. Press the "A" button. SECONDS will blink. Set them with "C". 5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button. 6. Press the "A" button again, and HOURS will blink. Set with the "C" button. 7. Press the "A" button again, and 12 or 24 hours tim format will appear. 8. Push in the "M" button to its normal position.
To set the calender 1. push the "M" button to move the mode hand to (CAL) 2. Set the city using the "A" or "C" buttons. 3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month. 4. Push the "A" button. The date (day) will flash. Adjust with the "C" button. 5. Push the "A" button. The YEAR flashes. Adjust with the "C" button. 6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands: 1. Press the "M" button until the mode hand is in (TME) or (CAL) mode. 2. Pressing the "A" and "C" button together. The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps. Source: how to set time on a bulova marine star 96C30
This solution is from fixya member ropickym Fixya
Jul 03, 2014 | Bulova Marine Star 96C30 watch
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    How do I set my pod 535 watch after I have changed the batteries
    Just tried this procedure to replace a watch battery in a POD 535 and did not work...my version of the watch might be different, all I am saying is it did not work with my watch.
    The procedure that worked with my watch
    When you have replaced the battery reset the watch by placing a small screw driver across the two recessed contact next to the lower battery clip. The digital display will reset and you will see four zero's flashing...if not press the winder button once, or reset the watch again. This process is to get all the hands at twelve O clock position...press and hold the top right hand button and the hands will start revolving...you can let go of the button once the hand are moving. Pressing the top button again will stop the hands and a short press will move the hands in small increments. Once the hands get close to 12 press then press the button once and then press the same button in short pulses to align all the hands on the 12 position. Wait a short time and the watch will find the time signal and both the digital display and hands will be aligned and showing the correct time.
    Oct 29, 2011 | Garmin Forerunner 50
    My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
    Welcome to Fixya,
    The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
    1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
    2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
    3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
    4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
    5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
    6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
    I hope this will help you.
    Thank you for usinf Fixya.
    Feb 21, 2011 | Watches
    Oh, one additional thing about my CASIO 'WAVE CEPTOR' watch: After I got (finally) the manual and set up the watch, it set the DIGITAL display to the correct time & date, but the ANALOG display re-set...
    You can align the analogue time with the digital time by pressing the mode button until you reach the hand setting position (HS) and then press one of the right hand buttons to change the hand position.
    (Check out this with the instructions- it is all there!)
    May 07, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
    First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
    Jan 28, 2010 | Watches
    Need instructions for my sr927w accurist watch
    QUICKSTART - SET THE TIME
    1. Push the bottom right hand button until the mode hand indicator points to TME.
    2. Press and hold the upper left button for three
    seconds. The hour and minute hand will retract to the 12
    O’clock position.
    3. Select the time zone on the digital display by pressing the
    upper right button or the lower left button.
    4. Pull the bottom right button out one click. The bottom part of
    the digital display will start flashing. Press the
    bottom left button to adjust for daylight saving time.
    5. Press the upper right button. You will see the seconds
    flashing on the lower half of the digital display. Press the lower
    left button to reset the seconds to 00.
    6. Press the upper right button. You will see the minutes
    flashing. Press the lower left button to set the minutes to your
    current time.
    7. Press the upper right button. You will see the hours flashing.
    Press the lower left button to set the hours to your current time.
    8. Press the upper right button. You will see 12H or 24H
    flashing. Press the lower left button to switch between 12 hour
    and 24 hour.
    9. Push the lower right button back in.
    SET THE CALENDAR
    indicator points to CAL.
    2. Press and hold the upper left button for three seconds. The
    hour and minute hand will retract to the 12 O’clock position.
    4. Pull the bottom right button out one click. You will see the
    month flashing on the digital display. Press the lower left button
    to change the month.
    5. Press the upper right button and the date will begin flashing.
    Press the lower left button to change the date.
    6. Press the upper right button. You will see the year flashing.
    Press the lower left button to change the year.
    7. Push the lower right button back in.
    SET THE ALARMS
    indicator points to AL1, AL2 or AL3.
    4. Pull the lower right button out one click. You will see ON or
    OF flashing on the digital display. Press the lower left button to
    turn the alarm on or off.
    5. Press the upper right button. You will see the hours flashing.
    Press the lower left button to change the hour.
    flashing. Press the lower left button to change the minutes.
    SET THE TIMEZONE
    1. Setting the time zones allows you to add or remove cities on
    the digital display or switch between daylight saving and
    standard time. Begin by pressing the lower right button to move
    the mode hand indicator to SET mode on the bottom dial.
    2. If the hour or minute hands are obscuring the digital display,
    press and hold the upper left button for three seconds. This will
    cause the hour and minute hand to retract to the 12 O’clock
    position.
    3. Now pull the lower right button out one click. You will see the
    digital display flashing. Press the upper left button to select
    SET to display the city or OFF to not display the city. Press the
    lower left button to turn summer time on or off. Summer time is
    indicated on the lower part of the digital display. Daylight
    savings time must be manually set for each city.
    4. Pressing the upper right button will allow you to scroll
    through all the cities. After setting, push the lower right button
    back in.
    USING THE TIMER
    1. Press the lower right button to move the mode hand
    indicator to TMR mode on the mode dial.
    position.
    3. Pull the lower right button out one click. You will see the
    minutes flashing in the digital display. Change the minutes by
    pressing the lower left button. Once you have set the minutes
    on the timer, push the lower right button back in.
    4. Pressing the upper right button starts and stops the timer.
    5. Press the lower left button when the timer is stopped to reset
    the timer to its initial preset time.
    USING THE CHRONOGRAPH
    1. To use the chronograph press the lower right button to move
    the mode indicator hand to CHR mode on the mode dial.
    3 .To start or stop the chronograph press the upper right
    button. If you press the lower left button it will display the split
    time for 10 seconds.
    4. When the chronograph is stopped press the lower left button
    to reset back to zero.
    SET THE TIME ZONE
    the mode indicator hand to SET mode on the bottom dial.
    savings time must be manually set for each city..
    through all the cities. After setting, Push the lower right button
    back in one click.
    Hope this helps. =)
    Oct 10, 2009 | Bulova Watch
    I,m in Uk, my watch digital display is correct but not hand displ
    you have to go throught the watch menu like your going to change the time. but there is one for the analog when you find it change the time with the start and stop button just like the dig display. you have to hold the button down as the hands scroll.
    Jul 11, 2009 | Nixon Insider NIX0033 Wrist Watch
    Cannot get watch hands to sync with the digital time. mine is movement ''c320'' older watch, citizen ''navisail'' stars and stripes 2000 special edition....america's cup watch.
    pull stem out and push all other buttons a b c at same time to reboot next step advance hands min/hour/sec to 12:00 push in stem M and start your reset
    May 09, 2009 | Citizen Watches
    Timer instructions for a Rangemaster Toledo dual fuel 90 required
    OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
    The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
    For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
    TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
    TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
    TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
    GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
    Dec 22, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
    Cell Phones Logo
    29 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
