Question about LG Flatron 563LE 15.1" LCD Monitor
Black screen on my LG Flatron lcd 563le
I changed my LG-monitors resolution in Windows XP Home from Low to Middle and the monitor said "Out of frequency" and the screen was black after 8 seconds. What shall I do? Without screen I canĀ“t reboot or switch off my computer. Bjorn
I solved the problem myself by disconnecting the monitor from the computer and then I unplugged the computer. I restarted the computer in position fail safe (F8) and tried to change the monitors resolution back to origin, failed to do so and rebooted instead. When Windows loaded up the problem was gone! Yipeyiiiii!
Bjorn
Posted on Jun 04, 2009
HOW TO FIX LG FLATRON 1750HQ OUT OF RANGE WITH WINDOWS XP?HOW TO START THE MONITOR ON A WINDOWS XP IT WORKS ON VISTA HOWEVER ON XP WINDOWS IT SAYS OUT OF RANGE WHAT ARE THE CORRECT SETTINGS FOR WINDOWS XP...
your refresh rate is set too high. boot into safe mode set to 640 x 480 then reboot. once it is up try adjusting the refresh rate to around 60 or lower. or buy a newer monitor.
May 20, 2014 | LG Flatron 563LE 15.1" LCD Monitor
Not able to use full screen
This sounds like bad resolution is set on your computer. The LG 22" FLATRON monitor has a native resolution of 1680 x 1050. However, your video card may not support this so you can also try any other 16:10 resolution like 1440 x 900.
To change your resolution in Windows XP:
1. Access the Control Panel.
2. Choose "Display".
3. Click the "Settings" tab.
4. Under "Screen resolution" move the slider to a 16:10 resolution like 1680 x 1050 or 1440 x 900.
If you computer does not support higher resolutions, you may consider replacing your video card to take full advantage of your nice 22" Flatron monitor.
If I can further assist you, please let me know.
Regards,
KYTechnology
Mar 01, 2011 | LG 22" FLATRON LCD Monitor
How can I have a driver for monitor LG flatron LCD 563LE?
You can download the Drivers for your monitor from the LG website.
Jul 11, 2010 | LG Flatron 563LE 15.1" LCD Monitor
Flatron L1750S (Silver, Black) 17" LCD Monitor: Out Of Range - what does that mean...
Your PC video resolution is too high for this monitor to display, you need to set your PC video reslotion to the native resolution of this monitor, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
Hi for all,a nother LGflatron LCD 563le problem
hsonic75, You need to do the flashlight test the next time your LCD goes to a black screen. Make sure that PC is fully booted with a Windows Desktop showing. then reconnect the 563LE to PC. Turn on the 563LE and note how long it takes to go dark. After you get dark screen, shine bright flashlight at different angles close to screen. Do you still see a faint image of the desktop? Let me know results of test. How old is this monitor? Is it covered by a warranty? Have you called LG (Lucky Goldstar) to find out if they have a swapout program? You send your monitor+$40-$90 and they ship you a same model REFURBISHED(with new CCF tubes/SMPS/INVERTER boards) back to you. Your complaint sure sounds like an INVERTER or Switch-Mode-Power-supply problem to me! All you need to do is a search on net for: 'bad caps in lcd monitors' or 'bad caps on lcd boards' and you will be inundated with more than you need to know! I'm louie12fix on fixya or lmistyrel@ aol.com
Bye for now.
Apr 15, 2009 | LG Flatron 563LE (White) 15" LCD Monitor
My lg flatron 563le monitor is a bit brght
auto on the front will usually fix this however theOn Screen display has a brightness setting and its straight forward,
Mar 22, 2009 | LG Flatron 563LE (White) 15" LCD Monitor
Monitor problems
Try setting your resolution lower via the control panel; it appears the resolution picked by Windows is beyond the monitor's capabilities.
Dec 13, 2008 | LG Computers & Internet
LG Flatron 563LE 15.1" LCD Monitor Logo
323 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
