Question about ASUS 90-A4C1K1000 Keyboard
Loose key on my ASUS laptop
I have a loose key on my ASUS keyboard, how do I fix it, I have tried pressing it down but it keeps on coming off.
SOURCE: Asus Keyboard Problem
Hi!
You may have a problem with the keys on your keyboard sticking. And it could be the ALT key that's sticking. You can try to remove the keyboard unplug and reconnect the cable underneath it. Or better yet, try an external keyboard see if its doing the same thing so that you will have a better conclusion if its the keyboard or just the settings on your OS or BIOS.
Hope this helps!
Karlox
Posted on Dec 26, 2007
SOURCE: I spilt my drink on my laptop keyboard...
you can pull the keys out of their sockets and wipe the rubber and plastic holders with a wet cloth. but be very carefull to cloth should not leak, just be wet to dissolve and absorbe the sugar and other stuff that stick the keys. then just insert the keys in the sockets
Posted on Jan 09, 2008
colliewob
  • 778 Answers
SOURCE: Asus x55 laptop keyboard problems
Try another keyboard I think yours is faulty may have had moisture or water on it this is usually what happens. not straight away but through inner corrosion
Posted on Jul 17, 2008
SOURCE: Asus w2v laptop keyboard problem
Press Fn + Numlock. You have the number lock on, but laptops don't have a number pad. So it re-assigns these keys to overlay some existing ones. Once your number lock is turned off you should be ok.
Posted on Aug 08, 2008
benwabnick
  • 2404 Answers
SOURCE: How to reattach the F12 key on my Sony Vaio
Sounds like the cat did more then just damage the F12 key. If the plastic connectors underneath the F12 are damaged or the white tactile is damaged then they keyboard is done in that aspect. What worries me more is that the right hand side of the keyboard is not usable.
What needs to happen is the keyboard needs to be taken out and reseated back into its slot on the motherboard and see if you can use all of the keys again minus the F12.
If you can then use the keyboard until you can get another one.
If you get the same results (not being able to use the right hand side of the keyboard) then the keyboard is bad and would need to be replaced ASAP or you can use an external usb keyboard for now.
Posted on Jul 15, 2009
Some keys laptop keyboard not working
Rarely does anything good come from dropping a laptop. It could be a loose connection or the keyboard needs replacing. Open the laptop and reseat the keyboard connection.
May 28, 2013 | ASUS Recertified - U46 Series U46E-BAL5...
Suddenly keys "ESC", up, DOWN and "p" stopped working. No water was spoiled, nothing was done. At the evening they worked, in the morning not. I might have accidentially pressed some...
It might be a loose keyboard connection. Try dusting debris out from the keys. Next, try re-seating the keyboard cable/ribbon to the system board.
Nov 09, 2012 | ASUS K40IN Notebook
How do you fix the keypad? I cannot type anything
Sounds like the main lead of the keyboard has come loose, either that or the key board needs to be replaced. Here is the link to the video instructions on how to replace, I would follow the instructions on the removal and check the main power cable of the key board and make sure it is not loose before you buy another key board, cost for a new key board should range from 8 to 15 dollars. http://www.youtube.com/watch?v=1vRglqfQjyE Hope this helps. :)
Sep 04, 2011 | ASUS Eee PC 1000H Laptop
On my keyboard the number nine doesn´t work... i have the ASUS eepc1000H
Try to push it down then compare it to the key next to it. If you notice any difference, most likely it just came loose. This is simple to fix. First, push it down somewhat hard. It very well might click back into place. If not, you will have to gently take it off. Tell me what you figured out and I'll try to help more!
Oct 07, 2010 | ASUS Eee PC 1000H Laptop
How come my laptop keys are harder to press than usual? This started when I pressed the keys down very hard. I have tried pulling them out just a little bit but did'nt work.
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Sep 06, 2010 | Acer Aspire 5315 Notebook
Laptop keyboard is not responding & as far as I know no liquids have been spilled on it. Is there a key that my son might have used to disable it? It is a HP laptop
probably your son might lock the keyboard what you have to do is that on the keyboard you will see where they wrote Fn key beside the ctrl key hold or press the key, then on top of the functional key i.e F1 to F12 among those keys you will see where they draw or shown something like key or padlock press the key in other to open your keyboard.
In case it doesn't work try the second option.
well, what i can say is that try to loose the laptop you will see where they wrote kb at the back of the laptop then loose those screw after loosing it, then bring out the keyboard with the flex then dust it out.
if it those not work again change the keyboard.
Jun 14, 2010 | Computers & Internet
Key on keyboard came loose
This is issue with laptops when you type fast sometime you hit the keys from the side and overtime they come loose or from overheating…the only way is by replacing the keypad…sorry.
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Sep 17, 2009 | HP Compaq Presario CQ50-140US NoteBook
HP Keyboard
adere some super glue to the outter circle of the F key underneath and push it back into the silicon. make sure you don't keep the key pressed down while the glue dry.
Aug 21, 2008 | HP D8597A Keyboard
Computers & Internet Logo
683 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
