Question about Honeywell Heating & Cooling
Need size of HVAC dual run cap
I have Armstrong Concept 10 with bad dual run capacitor. Not sure what size to get. Rust makes it difficult to read any labeling.
    Guru:
  • 1,524 Answers
Model number please.
Posted on Jun 02, 2009
  • jonathan balaban Jun 17, 2013
    scu10b24a-1a
  • Robert Moller
    Robert Moller Jun 17, 2013
    This unit uses a 30/3 mfd 370 Volt dual capacitor
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
Aug 08, 2017 | Heating & Cooling
Which capacitor? I have a armstrong air high efficiency concept 10 air conditioner, the model sticker is unreadable, the capicitor is also some numbers on the capacitor: 7355a14 70vac 98 -60hz 812
That info probably won't help. You'll need to get the compressors' make and model number. Call a dealer for the maker, or search it online. Look for a number like 35 or 40 or 45 or 50 and so on up to 80. This number will be followed by a UF. So 50uf would be a 50 microfarad capacitor. May also be 2 numbers like 50/5uf. That's a 50 and a 5, dual capacitor. If you can read some numbers, you may be able to move it just right in the sunlight to see what you need if you know what to look for, sometimes. Hope this helps!
Apr 07, 2017 | Heating & Cooling
I have an Armstrong concept 1200 what size dual run capacitor does it take
the capacitor designation is printed on the side of the capacitor
call the service agent for the unit and give them the details on the plate
Sep 19, 2016 | Heating & Cooling
Armstrong concept 1200-bad start/run capacitor?
Yes, most likely the start capacitor has failed & should be replaced. You have proven this by being able to hand-start the fan. Once replaced, the compressor should kick in & work fine.
Jul 20, 2012 | Heating & Cooling
My Armstrong Concept 1200 stopped working yesterday (model EFC14MAA-1A, Serial # 6099F44101, 42000 BTUs). All breakers are OK. On the outside compressor unit, I can depress the relay and the fan and...
sounds like your problem is in the air handler. Sounds like the fan is not kicking on in the air handler this could be the board or the cap or fan motor you can run a micro farad test on the cap that goes to your evap motor be sure you take the leads off the cap and the mf are written on the cap itself. does the outside suction line which is the big line starting to freeze up? you can check your motor winding by running an ohms test across the motor winding. You do this by reading on the motor which wires goes to your start and run windings. You should get and ohms reading and if they are bad you will get infinity.
Jul 31, 2011 | Heating & Cooling
I have an Armstrong Concept 1000 that has an AO Smith condenser fan and the purple wire has come off. There are 3 wires, black, brown and purple. Black is connected, Brown connect sto capacitor and where...
Purple goes to the run cap.Trace the brown wire to the cap.The purple wire plugs next to the brown.The cap has letters on top of the can plug it on the COMMON post.
Dec 08, 2010 | Heating & Cooling
I have an Armstrong Air Concept 1000 AC unit won't turn on
Neither of the above solutions are correct. You need to replace the capacitor 35/5 uhf 370 vac the cost should be $15 or less at a local HVAC retailer. Make sure you have the breakers off plus pull the contacts out which are inside the big box connected to your house. Make sure you pay attention to where the wires go. The red wire goes to common, the yellow to compressor (herm) brownish to the fan. The capacitor will be oval not round <!-- from fixya rte -->
Jul 10, 2010 | Heating & Cooling
Heating & Cooling Logo
948 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
