Question about Mitsubishi VS-50605 50" Rear Projection Television
Need info onhow to fix
Pin and trap out ajustment & need convergence
  • caupshaw2000 Jul 19, 2008
    TV is showing shadows of red, blue, and green separately. also areas around edges not showing any pix. It seems like its just out of focus. please help.
    Problem Solver:
  • 4 Answers
Some tv have an auto convergence reght in the on screen menue . Depends on your TV brand
Posted on Jun 08, 2008
The cross hairs on my television dont seem to come together as much as i try they dont budge i cant watch tv because the convergence is so bad will i have to hire a professional or is there something i can do myself to fix this?
Posted on Jun 07, 2008
Brand new lcd 52 in mitsubishi,red green color problem
Posted on Jan 01, 2008
    Genius:
  • 1,694 Answers
Fix convergence issue first = bowing / distortion will go away.
Requires changing large STK IC's and possibily a pico fuse
in the power supply......................T.
Posted on Dec 04, 2007
How do you ajust the horizontal hold and the focus
This may actually be a convergence problem. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 26, 2011 | Zenith R45W46 45" Rear Projection...
I try to ajust the green convergence on reference mark down ,and i can't move this line to left or right. how i can ajust the lamp to the righ or left. thank you
Ur tv 100% have a problems known as a convergence picture peoblems.The tv convergence board it is dead,if any of the colors lines R,G,B mis alignments and u will not able to auto or manually to adjust any of the R,G,B colors lines to alignments any of them up.The tv convergence board must be replace like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
May 29, 2011 | Panasonic PT-47WX51 47" Rear Projection...
How do you fix the Convergence, Can it be a fix
No,Ur 2 STK convergence ICS are dead,and some or all it resistors are too.The shop will cost u $300-350 for parts and labors.
May 15, 2010 | Apex Digital GB4308 43" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
The picture on my Mitsubishi rear projection big screen has pink and green lines going around all of the images
you will need to ajust the convergence of your tv. there should be a "test" swich/feature that brings up a grid on the screen. ajust the horizontal and vertical of each of the colors until the lines become white. you will need to be more specific on which model you have if you need more detailed instructions. it should cost less than $75 to get a tecnician to come over to fix this.
Aug 08, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
My convergence problem is the green convergence missing in menu
the only info you need is to replace the middle chemical fuse next to the flyback, I believe it`s marked "231" on most sets and then the critical parts is to re-solder ALL of the pins on the flyback transformer, 9,10,11 are usually cracked big time but you need to solder all of them, I`ve done this 50 times and never had a call back, gl, video-tek
May 29, 2009 | RCA HD52W59 HDTV Projection Television
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
I cannot ajust the colnvergence blue is ok can"t ajust the red
Depending upon the set, the probable issue is either poor connections on the pins of the convergence IC or a defective IC. If you can update this with the make and model, I can confirm this and provide additional details and instructions.
Dan
Dec 09, 2008 | Televison & Video
IC's in the TV
Replace convergence IC's.......Do you need step-by-step help?
Let me know.........T.
Nov 08, 2007 | JVC AV-56WP74 56" Rear Projection...
I need to no the code to the convergince eprom
The convergence is adjustable from the customer menu. If you cannot adjust the convergence properly you may have a bad convergence IC if either the red or blue wont move in any or only one direction or line up with the green. Remember, convergence on a Picture Tube Projector is never 100%. However, if you have a template and want to do a total setup you can enter the service adjustment menu by using the origonal philips remote pressing 062596 INFO. Take extreem caution not to mess with any adjustments without writing down the values first.
Oct 31, 2007 | Philips 50P8341 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
