Question about Canon SmartBase MP360 All-In-One InkJet Printer
Can't find windows 8 driver for canon smartbase mp360
Could anyone help me find canon smartbase mp360 driver for windows 8 please.
SOURCE:
jonniewalker
  • 1031 Answers
SOURCE: error code printer check ** 343
the error is "Waste Ink Tank Full" error
This error occurs after a set number of nozzle activations, and it's to protect you from having ink start leaking out of your printer.
The waste ink tank is actually a large cotton pad in the bottom of the machine which absorbs the waste ink, and if this pad becomes full, the ink will pool and, like water, seek the path of least resistance, which could be where the case parts connect, and then leaking out onto your desk or carpet...
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu Copy Copy Copy Scan
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
hope it works for your model
Hope it helps.
goodluck pls dont forget to rate this
Posted on Sep 21, 2008
SOURCE: Canon Smartbase MP360 waste ink nearly full
Try thise site good luk..
http://www.fixyourownprinter.com/forums/inkjet/24191
Posted on Mar 27, 2009
Fixe_You
  • 1800 Answers
SOURCE: Canon SnartBase MP360 goes through motions of
try to unplugg it install drivers then plugg and reboot and try a teset page.
Posted on Jun 05, 2009
michael_grey
  • 365 Answers
SOURCE: Canon Smartbase MP360 showing error code ##336
It seems the home position sensor is out of whack or the mylar band behind the print cartridge carriage is missing or broken.
To find the mylar piece look for a clear 6mm x 460mm clear piece of plastic with black markings (like a gradient) on both sides.If you find it you can try and place it back by looking for an extended eyelet on both sides of the stell print carrier.
Most people in haste to change ink have the hand slip and it becomes dislodged.
Posted on Jun 17, 2009
L0rdL0ki
  • 45 Answers
SOURCE: What does ##343 mean?
##345 is jammed cartridge error. Reasons could include:
-Foreign material or dried ink in head cleaning unit (also known as "purge unit") , or waste ink pump jammed up. Make sure waste ink pump rotates freely, after cleaning. Clean the waste pump-hose too! Waste ink pump is located under head cleaning system.
Symptons are:
-Grinding noise (very loud)
-Flashes error code ##345
Short fix:
1.Take apart and wash the ink clogged mechanical parts. Use hot water.
2. Reset waste ink counter
Long fix:
The following operation takes several hours / days to complete.
-Take apart the whole printer, so there is only a metal frame left, with couple of paper-rollers, and motors, and the "Print-head cleaning" -system. Wash this cleaning-system.
-Mark all wires that look the same (especially white flat ones), take photographs when disassembling.
In detail, remove at least following items:
-Main Power lead!
-Casing (Use bright flashlight to see TWO front cover-screws under the dark plastic!)
-Scanner (BEWARE of fragile flat-wires)
-Main electronic controller board
-Metal plate, plastic cover, and some others.
-Plastic base plate
-All materials that might absorb water. (two sponges, and one rubber foam part)
The two sponges are between metal frame and base plate, they absorb excess ink. Wash these separately, and dry, or change for new. (I left the shorter one out, when assembling)
There is also one long rubber foam part that is near where paper comes out, (visible from outside the printer, when cover is opened).
To get rid of the excess ink: Wash dirty parts heavily for 10 to 15 minutes with hot water. When out-coming water is clear, then it is clean.
-Let it to dry for couple of days, but you can use your imagination - compressed air could help it dry faster.
-Assemble it back together
How to reset waste ink counter (you should clean the printer also):
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
2) Select TEST MODE (press right arrow button 13 times).
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Cleaning the print head:
At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
-Remove print head assembly from printer.
-Remove ink tanks.
-Use running warm water, wash away the excess ink that is dried around the print head.
-Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
(-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
-Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
-Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
-Run Nozzle check, cleaning, print head alignment.
This should do the trick.
Answer extracted from service manual and Techimo.
Good Luck,
-LL
Posted on Feb 23, 2010
Testimonial: "Thankyou for detailed solution - appreciate it enormously. The only thing I´m still pondering on is it says: ##343. Is it equivalent to ##345? Nikita"
ISTALACION DEL SOFGUAR DE CANON MP360
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and
select your model printer todownload : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Aug 04, 2011 | Canon SmartBase MP360 All-In-One InkJet...
Can not download canon imageclass mo360 driver into my new laptop
hello. You need a new driver. They are a free download at Canon.com
Mar 03, 2010 | Canon SmartBase MP360 All-In-One InkJet...
Hi my Canon smartbase mp360 only prints text but not pictures?
Please install ' Easy-Photo print' software from the CD received with the printer.
Jan 28, 2010 | Canon SmartBase MP360 All-In-One InkJet...
Jun 05, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Smartbase MP360 Scanner Not Identified by MS Vista
One thing to check and be sure of is that your printer cable (USB) is definately a USB 2.0 cable. Canon have an issue with their printers with scanners in that the data flow sometimes isn't sufficient when an older USB cable is used. The slightest drop of data on startup or during scanning will cause a stop.
Worth trying and has sometimes solved the problem for my customers.
Aug 23, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
209 people viewed this question
Clive
Clive
old marine
old marine
Ekse
