Question about Microsoft Windows XP Professional with Service Pack 2b Full Version OEM for PC
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
My operating system is Windows Xp When ever i run C programme below given message appears 16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Posted on Dec 11, 2011
  • app_3rp40130
    app_3rp40130 Sep 15, 2012
    where can i find the TC directory ?
  • 358 Answers
You have to download turbo c v2.01 . which can be got here
http://edn.embarcadero.com/article/20841
to download it you just have to join the developers group
after downloading it extract it . then you will get 3 folders by namedisk1,2,3 . then press install from disk 1 after installation it willask to enter 2 disk. so you cancel the setup and come out of it. thencopy all the files from disk 2 and disk 3 and pate it in c:/tc . whichis already created . enjoy now your tc.exe will work. enjoy . try it 1000% guarantee it will work . because i was also facing the same problem
Posted on Feb 01, 2010
  • 28 Answers
Try using DOSBox 0.73, it's free. It emulates an x86 processor with DOS. It might work. Otherwise try to get an old CD-ROM based installation disk for MS-DOS and run it in Microsoft Virtual PC
get dosbox at http://www.dosbox.com/
or
dosbox.sorceforge.com
Posted on Jul 16, 2009
Ntvdm cpu encountered illegal operation Hi all! I just installed Maya 2010 from a torrent file and since then I got this famous error message. It's just appeears as three command prompts appearing at the...
If I am reading this right your issue is not the application but where you obtained the application. Maya 2010 is a modern design application and comes in 32 & 64 bit versions. It is not a 16 bit application.
When Windows encounters a legacy application it calls the NTVDM for the legacy application to run in.
The fact that the application is calling the NTVDM is highly suspicious. NTVDM is the NT Virtual Dos Machine, a way for legacy applications to run in NT environments.
NT environments are Windows NT 3.5, NT 4.0, Windows 2000 Professional, Windows XP (Home, Pro & Media Center Ed), Vista (all versions) and Windows 7.
Old (legacy) applications written for 16 bit date back to Windows 3.1 and include Windows 95, 98 and Millennium Edition.
I would obtain a copy of Maya 2010 from a reputable outlet instead of Bit Torrent as "warez" frequently contain malicious items that will infect and ruin your machine.
Feb 05, 2010 | Microsoft Windows XP Home Edition
I cannot able to run Borland Turbo C++ 3.0 As it displays the following error messages. 16 bit Ms- Dos subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction. CS:0000 IP:0075 OP:f0 00...
If you are trying to run this 16 bit app on a 32 bit XP system, then errors will happen. Right click on the apps desktop icon and go to PROPERTIES and click.Then click on the compatibility tab. Here you change it to operate in the 98 Windows emulation. Save and start the app.
This will work if you are logged in as Adminstrator. If not you can go back to the instructions above and when the properties window opens click on the first ADVANCED button you see. There you make sure both the " log on as..." and seperate memory space" check boxes are ticked. Then save and it should now open in a seperate memory space just like the older systems that this program was made for.
Good Luck
Dec 18, 2009 | Microsoft Computers & Internet
Turbo c not working....16 bit ms-dos subsystem error
There have been several changes in the way programs work. Windows xp does not
allow direct access to hardware resources to protect system integrity.
However you can try a few things
http://support.microsoft.com/kb/314106
http://support.microsoft.com/?id=165214
http://support.microsoft.com/?id=324767
Generaly speaking this error shows up when a program tries to use a
command.com file from an incompatible version of windows.
Alternatively login in safemode and use. it ll work fine. rate this!!
Aug 15, 2009 | Borland Turbo C++ 4.5 Full Version for PC
Error while running graphic programs in turbo c++
try using 32-bit processor, and it iz very cheap now-a-days.
bye
Aug 13, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
16 bit error while using turbo c graphics...........
Try running Turbo C with administrative priviliges and running it as Windows XP SP2 if you have Vista. Seems to work for me.
Aug 04, 2009 | AMD Sempron LE-1300, 2.3 GHz...
16 bit MS DOS Subsystem error
I found a website of people who have the same problem;as you will see Microsoft does not have a fix for it. The recommended fix is to backup your data and reload Windows.
http://www.techspot.com/vb/all/windows/t-5039-NTVDM-CPU-illegal-instruction-.html
Pls rate this solution.
Apr 13, 2009 | Microsoft Windows XP Home Edition
Windows problem
Try this.
Right Click on your DOS program EXE file. Then go to properties and go to Compatibilty TAB. Click in Check Box for Compatibitlity mode and select WINDOWS 95.
Feb 10, 2009 | Computers & Internet
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
The ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional with Service Pack 2b  Full Version OEM for PC   Logo
6,059 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
