Question about Oreck XL Ultra Bagged Upright Vacuum
Wiring Just removed hair, etc and had to remove the motor and clipped the light wires. Reinstalled but blew lights. Wired series> wired parallel> deffinetly wired wrong have a diagram?
  • 5 more comments
  • rehoe Dec 07, 2007
    THE MODEL IS A XL9100C Seial 1269611
    E-Mail is a
    Check above I can handle any schematic.
  • numbbers Jan 06, 2008
    I need the motor wiring schematic for an Oreck XL 2600HH vacuum cleaner.
  • BarryCr Feb 07, 2008
    I'm having difficultly replacing the motor in an Oreck XL. I can't get the old motor out. Where can I find a guide for tackling the project. Thanks
  • Ike722 Feb 15, 2008
    I have an XL 9100 and need a wiring diagram
  • laurelview Feb 23, 2008
    have an xl model u4080hpd. need wiring diag. Its a two speed.
First, what is the model number? I'll shoot you a wiring schematic.
Posted on Dec 07, 2007
    Problem Solver:
  • 9 Answers
Backwards wiring. The motor will still run but the lights keep going out right?
Posted on Dec 06, 2007
  • JRO173 Dec 07, 2007
    I'll shoot you a wiring schematic, what is the model #
How to properly wire the cord at the switch on Oreck XL Pilot Series? Wired it wrong during a cord replacement at the switch. I couldn't remember which prong to put the black wiring on. Switch has 3...
Joanne, when you take the screws out of the handle, and take the handle half off to expose the switch, the black wire from the handle cord goes on the front terminal on the switch that is by itself. The black wire from the power cord will go on the terminal that is facing up as you look down on it. Hope this helps!
Jan 23, 2015 | Oreck Vacuums
My shark infinity vacuum has no power to it. It just quit mid vacuuming, almost like the wires inside got got pulled out. Is there a problem with loose wiring or motors burning out suddenly?
Sounds like it needs cleaning.
Remove all filters, clean or replace.
Clean motor.
Clean brush rollers.
Clean everything.
There is an inline fuse which shuts off power if too much dust, hair, etc blocks incoming air.
It resets after awhile, when van cools down.
Oct 08, 2014 | Vacuums
How do you rewire a relay
The relay contacts are wired in series with the motor, circuit breaker and switch. The relay coil is wired in series with the transformer secondary circuit, the control wires to the valves in the wall. Also the on switch is wired in parallel with the control wires.
You did not ask about the transformer but the primary windings are wired to be always on. If you need a picture I can draw you one.
Jan 31, 2014 | Electrolux Central Vacuum
Wiring diagram
Are the wires still bundled or loose?
If bundled, there are 3 connections to the motor and they make an L shape (sort of). place the motor in front of you so that 2 connectors are on the left and the last is at bottom right. The thermocoupler attaches to the bottom right, usually black or orange wire with the metal device on it. The upper left is usually a 2 white wires clipped together from the power cord and the short junction to the light bulb. The lower left is for connecting the short wire for the bulb to the black wires in the light bulb harness. Just go counter clockwise: Power, light, thermocoupler and you should be in good shape.
Nov 06, 2013 | Hoover U6616-900 WindTunnel Bagless...
I nead a wirring diagram to fit a four connection power switch to a Kirby G4 cleaner
There isn't a wiring diagram for these. There is only a switch, a motor and a light, so a schematic isn't really required.
I'm assuming you've made the fatal mistake of removing the wiring from the old switch and have forgotten where to re-connect them. It's also not very helpful that all the wires are white, so I can't really tell you to connect red to "x", black to "y", etc.
The really important connections are the power cord and the motor brush connections. You can't get the power cord wrong as the plug is shaped to only allow connection at one orientation: I've drawn you a diagram to show 3 of the 4 connections:
As long as the motor brushes are correct, there wont be any problem. If these are the wrong way around, the motor will run in reverse and will blow instead of s/uck.
The headlight can be wired either way around so if these connections are switched, it shouldn't matter. You have a 50/50 chance of getting it back the same way as it was originally and if there is any problem with the light, you can easily switch these wires over.
Hope this helps. Please post back if you need further assistance.
Dec 16, 2010 | Kirby G4 Bagged Upright Vacuum
How do you replace the top shell of the Rainbow D series? It doesn't look like the wires can be disconnected without cutting.
To replace the top cap of a D4 Rainbow vacuum:
Remove the separator.
Remove the 4 screws on the bottom.
Pull the bottom off around the foam tank gasket.
Remove the next 4 screws.
Carefully pull the wiring up through the middle section wire hole.
Remove the top cap 4 screws.
On the bottom of the switch there are 4 fingers, one on each corner.
Push the fingers towards the center of the switch and push the switch through the rectangular hole
Pull the wire through the middle section and the top cap to give you as much loose wire as possible.
On the long sides of the switch near the wires are 2 small round holes with small semicircular tabs pushed through the sides of the switch assembly. These tabs hold the wire assembly in the bottom of the switch. Very carefully push a jewelers screwdriver between the switch body and the wire assembly on each side simultaneously to release the tabs and pull the wire assembly from the switch body. BE VERY CAREFUL. Do not pull the wires hard. The wires are held in the wire assembly by small friction clips. They are not soldered or attached except by the friction clips. These friction clips fall out very easily. The twist in the wires alone will pull them out of the friction clips. So hold onto the wires in such a way that they cannot twist free. If you loose a wire or two, you will have to push them back in and reset the friction clips. This was a challenge of dexterity. During factory assembly, The wires were probably pushed one at a time into the bottom of the completed assembly. You could record the position of each wire and replace them as the factory did. This was the most difficult step as the switch came apart very quickly and without warning and the wires very nearly separated from the switch assembly.
Remove the old top cap from the wires and replace it with the new top cap. A 3rd hand may come in handy.
Push the wiring assembly back into the switch body the same way it came out.
Push the switch back into the top cap.
Reassemble the vacuum.
Jul 09, 2010 | Rainbow Technologies D4 Bagless Vacuum
Rainbow E-series will not turn on
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also. Thank you, Ralph
One other thing. All E series vacuums have a built in circuit breaker on the motor. Some of the earlier ones, it was only a fuse, and if it blew, it had to be replaced, or removed and wired directly without it on there. Most of them have a automatic reseting curcuit breaker, that will blow and auto reset its self, after it cools off. They do sometimes stay blown also, and do not reset. If that is the case, it has to also be replaced, or removed, and wired directly, with out it on there.
Motor brushes are usually the source of a non working E-2 vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature.
Thank you again,
Apr 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Need a wiring diargam to look at
You won't find a diagram.
You will have series of yellow and white and sometimes gray wires on the outside of the motor housing and often a letter code etched on the housing , indicating the original wiring from years ago, red, blue, yellow, however the newer wiring eliminated those colors.
These wires are almost fool proof as they will align with the longest wire at the furthest point,a center one piggy backed , etc however before starting please post back to advise if you have removed the rewind and or motor and if so, did you disturb the motor wiring inside the motor shroud.
Please post the original problem you opened the vac for as well and I will try to walk you through this
Nov 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I have the same vacuum at home and can take a picture, but I believe it is wired in this order. Hot wire (black) from cord goes to the switch then the switch to the fuse, then the fuse to the cable that goes down to the light and motor. The neutral (white) wire from the cord is connected to the neutral (black with white stripe) side of the wire going to the motor and light.
Jan 26, 2009 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Oreck XL Vacuum
If you can find a Kirby G series vacuum lightbulb, it will work in the Oreck too!! Many sellers carry them online.
Apr 21, 2008 | Vacuums
Oreck XL Ultra Bagged Upright Vacuum Logo
673 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
