Question about Epson Office Equipment & Supplies
Epson TX700W printer won't start
Epson TX700W Printer "Move the yellow material as shown above" It will not move from this screen
The printer's ink pads are at the end of their service life. please contact epson support
Posted on Sep 13, 2009
My printer
Epson TX700W ink pads are at the end of there service life.
Jul 30, 2016 | Epson TX700W Series
A printer error has occurred epson tx700w
a printer error has occurred turn off the printer and turn it on again see your documentation
Apr 07, 2012 | Epson TX700W Series
PLEASE HELP! jusr bough and installed/setup my new Epson Artisan 710 printer. All the lights keep flashing and I have a message on the printer screen that says: "WARNING - move the yellow material as...
"All lights blinking and printer not responding" is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
The Solution is to try an older/another cartridge (doesn't matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper "dots".
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge's electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Good Luck & God bless!
Feb 11, 2011 | Epson Artisan 710 AllInOne InkJet Printer
Paper jam cleared but wont start
  1. Unplug the power cable.
  2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step five . Do not try to force it to move if it is hung up on something. NOTE: Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
    • If the carriage moves freely, skip to Step five .
    • If the carriage does not move, continue with the next step below.
  3. Remove the print cartridges.
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Remove the rear access door.
  7. With your fingers, rotate the rollers "up" three full rotations.
  8. Push the rear access door back into the printer until it snaps firmly into place.
  9. Replace the print cartridges.
  10. Plug the power cable into the HP All-in-One.
  11. Turn the power on.
Step five: Reload and test the printer Once the jammed paper is removed, verify that the printer is still functioning properly.
  1. Reload the printer with plain paper.
  2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
Step six: Service the printer Perform all the steps mentioned above. If problem persists, service the printer.
Oct 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Photo R425 will not print. Screen says "Paper jam" but no paper is visible. All docs. have been cleared from the document queue. A whirring sound occurs when trying to print. Any advice...
Please turn-off your printer and disconnect from PC then get a flashlight and try to look inside the printer starting at the paper loader mechanism. Try to look for paper or any materials that could have blocked a sensors path. Often this are not easy to spot and difficult to remove.
Contact me if this doesnt work.
Jul 22, 2010 | Epson Stylus RX425 Multifunction...
"tok tok tok" sound from printer
The carriage can not move freely. Open case. Check for something slip in roller, or may be some material that block carriage moving.
Sep 11, 2009 | Epson Stylus CX4800 All-In-One InkJet...
It cannot pass the first step
The yellow material is just to key the switch during shipping. It has no other function than that. Move on with step 2...3....4....and so on you'll see that message will go away. And the part about not connecting the printer to the computer until instructed, well that is important too. Also don't forget to remove the tape carefully from the bottom of the ink cartridges. Just take your time and you will do well.
May 15, 2009 | Epson Artisan 700 InkJet Printer
1,116 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
