Question about Epson Stylus CX6400 All-In-One InkJet Printer
Inserting A4 paper
I must be thick. I have bought Epson Stylus SX100, & installed OK. However, the manual is not very helpful, & I cannot insert paper for printing. Can you help I have the Epsom Stylus TX100, and I cannot figure out how to load the paper or even which side to load from. It comes with instructions (ink drawings) but they are not clear. This is idiotic, to not be able to load a printer with paper but even when finding the "slider" thing it still doesn't work.
  • 31 Answers
maybe this Site helps.
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX100-_E
Here you can find many documentations e.g. for your Epson Stylus SX100
Posted on Jun 02, 2009
I keep getting the message"the
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Mar 11, 2011 | Epson RX595 Photo All-In-One Printer
I cant find the Cd for instaalling the Epson stylus Sx100 what can i do
Hi i hope u 'll be fine
You can easily and free download the driver. To download free driver of Epson stylus Sx100 Download 'll automatically start after clicking.download then install it on your PC and Enjoy
I hope this solution will helpful for u. Best of luck
Kindly do rate if it is helpful
Regards
Mar 21, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
Epson stylus color 3000 printer operate,pause paper out and media type all led lights flashes. What is the problem?
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 21, 2009 | Epson Stylus Photo R1800 InkJet Printer
Glossy A4 paper will not feed. Is it too heavy?
Actually, if printer is new, printer can feed up to 350 grm. But if pick up rubber at paper feeder mechanics had distort/loose thickness, it can't. Try to use 210 gsm glossy paper. Or, if you wish to use 280 gsm, pull down paper while printer grab paper.
Aug 20, 2009 | Epson Stylus Photo 2100 InkJet Printer
Inserting A4 paper
You will be having a slider where you place the papers for printing, Use a A4 sheet and adjust that slider.
Regards....!
Mar 14, 2009 | Office Equipment & Supplies
Can't install Epson SX100
I found the right solution, at least to problem #2 on http://spazioiberico.spaces.live.com (in italian),
referring to http://www.tech-archive.net/Archive/WinXP/microsoft.public.windowsxp.hardware/2005-10/msg00987.html :
there was a missing Key in the Registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E979-E325-11CE-BFC1-08002BE10318}
Copy that key from a working PC, that's all. By the way, if your problem regards a scanner o camera instaed,
the missing key may be:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
Jan 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How to scan with the SX100
its easy.
When you have the paper loaded all u have to do is press the button that says "**** my balls".
You will find it below the power button.
Good Luck!
Nov 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Installing Ink Cartridges
I have a similar problem. I can get the print head into the appropriate position by using the ink cartridge replacement utility in the maintenance tab of the printer properties dialog.
Oct 05, 2008 | Office Equipment & Supplies
Epson Stylus CX6400 All-In-One InkJet Printer Logo
367 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
