Question about Behringer EUROPOWER EP2500 Amplifier
Link 4 speakers to behringer 2500 amp
Hi All, I have a quick question, is it ok to run 4 speakers through 1 Behringer 2500 amp? Amy speakers are all 8ohm. If so how should i do this? Many thanks, great website by the way! Glenn?
Glenn
2 Suggested Answers
  • 3 Answers
SOURCE: Behringer ep 2500
if after the pop it smells like a firecracker just went of than you fried the circit for that speaker or if it has fuses on it or ferther down the wire check them but it could be just the radio and nothin to worry about:)  a friends car does it, and it is very anoying
Posted on Jun 02, 2009
How do i connect a Behringer 1202 mixer to a Behringer B215D Powered speaker
Looks like both units accept 1/4" jack & I think the 1202 is unbalance out, so just use a standard screened mono (i.e. 2 pole "TS") jack to jack lead & you should be fine. Good Luck! :-)
Jul 28, 2014 | Behringer B215D Powered Speaker (550 Watts...
I have a behringer eurolive b212d no power no lights on when I push the button I hear a clike in the speaker but no power. tested the fuse its ok. could there be a fuse inside the power unit .any help...
Eurolive Active speakers from Behringer suffers of bad power supply/Amp design, if you open up the back of your speaker you will probably find that the AC connector has a burnt or loose connection as well as a black spot, if not, check the power supply/power amp coils for cracked connections, let me know for improve help.
Sep 20, 2013 | Behringer B212D Powered Speaker (550...
My Behringer 2500 wat pa amp keeps getting hot and cutting off
Step 1:
Overheating is typically caused by poor ventilation. The best thing is to make sure that you --
Step 2:
have plenty of space ALL-AROUND the amp
Step 3:
Fan(s) are working correctly (should always be on).
Step 4:
Boards are clean -- may require opening up housing and spraying with compressed air.
Step 5:
Be sure that the speakers you're pushing are acceptable to amp's output.
Step 6:
If still overheating, may require service.
Jan 07, 2013 | Behringer Music
Thank you for the quick response on my previous question. Again with the behringer pmp3000, can the PWR amp jacks also be used for mackie active speakers?
The answer is NO... These jacks need to float driving speakers that are NOT grounded in any way. Connection to channel A with a grounded cable will destroy the channel A amp. Use the 1/4 inch MAIN L & R jacks with balanced lines to active speakers. You can drive several active speakers from each of these jacks.
Aug 15, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I have two JBL MRX 515 speakers at 8 ohnms and two behringer bins at 300 watts 4 ohms running off a behringer EP4000 amp, would this be ok ? and not casue any damage to the speakers
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Behringer-EP4000-Amps-manual/id/23591dj795/t/2/
http://www.raltron.com/cust/tools/parallel_resistance.asp
It's ohm's law, dude. 1/a + 1/b = 1/total. One each 8- and 4-ohm speaker in parallel per channel would be 2.7 ohms (nominal). So it will work in theory.
How you manage the potential difference in volume between dissimilar speakers on the same amp channel is a mystery.
Distortion will kill any speaker, not power. Stay within the amp's usable range.
Jun 23, 2011 | JBL MRX515 15" 2-Way Loudspeaker Main /...
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
Behringer ep 2500
Jun 01, 2009 | Behringer EUROPOWER EP2500 Amplifier
Amp keeps blowing speakers
If the amp blew the speakers , it sounds like the amp pumped HIGH levels of DC voltage into the speakers.
Get another amp and not Behringer,not Pyle,not Gemsound and not Numark.
Feb 02, 2009 | Behringer EUROPOWER EP2500 Amplifier
How would i conect a ep2500 amp two 2 subs @ 4 ohms, or 8ohms
hey" i got 2 behringer 2500 amps and i have 2 peavey speaker that are 4 ohms 2000 watts eachand want to mono the amp separte,and i want to run 1 amp to each speaker so can you help me?
Nov 26, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
124 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
