Question about Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue PC Notebook
Toshiba satelite l355d laptop could not start and dark screen
I got this laptop from friend with spilled hot cappuccino they let it dry for two weeks it is now with me. when i turn on i can see three lights on do not start black screen but can here sound sound of fun.
what do you think the problem will be and if any simple fix solutions?
  • mular65 Jun 02, 2009
    ok i will try that but do not think has wet staff in it?
    It works well I clean up stack coffee cappuccino dried melt was stack every where.
    I have a fresh problem though when I open up the mouse moving button wiring line was hard to re install it after struggle I pout it back but mouse does not move?
    Problem Solver:
  • 8 Answers
Open the laptop equipment, dry with a blower, reinstall the laptop
then try to turn on.
Posted on Jun 02, 2009
Broken Laptop Screen: Toshiba Satellite c670-165
As in this model?
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/remove-replace-screen.htm
The Display Assembly is laid back to a point, that you can access the two bottom screws. Isn't a direct 90 degree position with the screwdriver. More like 60 degrees.
No?
Then the Top Cover (Palm Rest Cover) has to be removed, in order to access.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/remove-replace-lcd-screen-inverter-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
Don't forget to remove ALL power. AC adapter and Battery.
Regards,
joecoolvette
Jan 13, 2013 | Toshiba Computers & Internet
Toshiba satellite L355D screen is black
Try to remove the memory and clean..
place it back.
if not refix all the connections. or try change the monitor maybe monitor is dead.
Dec 21, 2012 | Toshiba Satellite L355D-S7815 Notebook
I spilled water on the keyboard and it won't fire up. What can I do?
If your Laptop is on when the water got spilled most likely it will cause harware problem I sugget if you are still under warraty to call the Customer Service of your manufacturer or the store where you bought it to check the coverage of your warranty and to what extend you are covered coz some company give warranty for accidents.
If you are already out of warranty then I sugget to call a local tech from your are to see what part got damage by the water so you will have an idea what to replace.
Hope this information will be helpful. Thank you for using FIXYA.
Apr 15, 2011 | Toshiba Satellite L355D-S7825 Notebook
Cant get past microsoft windows loading bar
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 26, 2010 | Toshiba Satellite L355D-S7809 Notebook
After cleaning for coffee spill dried up coffee spill my computer start well but i have touch pad unresponsive
You may want to open the laptop and check for damage to the touch pad including connection to the mother board. If you can not see any visible damage to pad or connection replace with another pad. Good Luck
Jun 02, 2009 | Toshiba Satellite L355D-S7815 Notebook
Toshiba L355D-S7815 - Spilled Juice - Short Circuit
Flip the lid open and flip the laptop (opened) and set it on a towel or something. It might take a week or a bit more to dry out. But you might be ok once it does dry out.
Although the best thing to do is to take it apart. And use a safe cleaner for circuit boards like alcohol (not wood alcohol).
Since you supplied power while it was wet. You could have have done permanent damage to the intergrated circuits. But let's hope not.
Jan 30, 2009 | Toshiba Satellite Laptop with AMD Athlon...
My toshiba screen
Shine a torch light onto the screen. If you can see a faint outline of the images, it could indicate a back light failure. Unfortunately, you cannot fix this by yourself. You will need to take it for servicing.
Jun 11, 2008 | Toshiba Satelite A10 Notebook
Toshiba Satellite Laptop with AMD Athlon 64 X2 Dual-Core Processor QL-60 - Onyx Blue  PC Notebook Logo
162 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
