Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
Smeg dishwaser problem
Hi
we put our smeg dishwasher on lastnight and for the 1st time in a long time it didnt finish the program.
the 2 outer lights are on and the inner 2 lights are off,.
it wont do any thing except turn on and beep when you press the stop/start button and even though water is still inside nothing happens except the lights showing the fault above
make n model:
type- 10045
model no- dwf 64 sse
3 Suggested Answers
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
jonniewalker
  • 1031 Answers
SOURCE: Detergent dispenser on SMEG DWF 44SS1 doesn't open
this is Usually caused by a tablet sticking in the Detergent Dispenser. This will stop the Detergent Dispenser from opening at the correct time on the wash cycle.
Posted on Oct 18, 2009
Help my SMEG dishwasher was stuck in a loop and when resetting it was going through the motions like it was trying to drain itself and then finishing the cycle so all 4 lights on the right were flashing...
completely unplug it for several minutes. if you do not have a plug, turn off the breaker to this unit for about 15 minutes. Then turn it back on and see if this resets it. Check for a reset button somewhere under the unit or on the door panel where the control buttons are if this is easier.
Mar 04, 2015 | Smeg Dishwashers
Hi can any body tell me whats wrong with my smeg dishwasher it only has program lights which now do not come on at all a part from the power light which beeps/but after that nothing
Probably computer is corrupt. Go to your circuit breaker panel and remove power from the dishwasher for a full minute. THEN< POWER back on. That should reset the computer.....
Jan 05, 2012 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg SNZ 614X. Using my usual 65 c program option , goes fine till the end of first rinse and then empties.. does 2 beeps and wont continue.All lights on the program side(on the right) then light up and...
Common problem with Smeg Dishwashers are related to the thermostat. You most likely need this part replaced.
Do you have a multimeter. I can guide you through some tests.
Ash
Sep 06, 2011 | Smeg Dishwashers
My dishwaser dosent finish its cycle it just keeps bleeping
if you are talking about the clean light blinking 7 times it is a water temperature problem either the heater element does not work or you need to run hot water at the sink by the dishwasher until hot to the touch or till at least 110 degrees before starting the dishwasher this should fix ya problem
Apr 03, 2010 | Whirlpool Dishwashers
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Smeg Dishwasher
replace the timer/control board
May 26, 2008 | Dishwashers
SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Mar 04, 2008 | Smeg Dishwashers
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
87 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
