Question about Dell Dimension 4600 PC Desktop
My Dell Dimension 4600 PC won't power up. When you press the power button the power light shortly lights up and the fan fan of the power supply rotates for a short time and stays off.
When you press down the power button the power light power shortly lights up and fan of the power supply rotates for a short time then stays off.
  • Cutlass85
    Cutlass85 May 11, 2010
    how old is the system and how much stuff are you running in it?
    like cd roms dvd burners that sort of stuff?
    Scholar:
  • 148 Answers
  • you may need to replace the power supply and ask a local computer technician to replace it
Posted on Jun 02, 2009
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Dell 4600 won't power up following lightning storm. PSU and power button both test OK. Suggestions please! many thanks
Check everything between the power supply and the wall outlet. If everything else is working using the same power a part of your computer is fried.
Jul 27, 2011 | Dell Dimension 4600 PC Desktop
I have a Dell Dimension 4600. I press the power button. The left light on the tower turns on amber, the right light comes on for 15 seconds or so then shuts off. The monitor will not come on, but will...
The most likely cause is a failing power supply. Unless you have a tester you will need to buy a replacement. Check the specs and order a suitable replacement. (www.newegg.com is my choice)
If any of this goes past your computer knowledge take your computer to an expert to examine first-hand.
Dec 26, 2010 | Dell Dimension 4600 PC Desktop
My dell dimension 4600 doesn't come on. When i press to on button I get an orange light on the power light ( left hand one ) then nothing happens. can you help
Possibly a faulty power supply?
Faulty Power cable?
Faulty Video Card?
Try replacing each of these in turn , remove all components and try to boot with the basics - 1 stick of memory, no drives, just video
Then add 1 drive
Then add another stick of memory
Keep going till you work out whats stopping it from starting.
Regards
1234s282
Apr 18, 2010 | Dell Dimension 4600 PC Desktop
The power supply light on the board comes on but when i hit power button cpu fan comes on for a second and doesnt come on
The first thing I would suspect here is the power supply itself.
Unless you have a power supply tester, thought, it's rather difficult to test it. I usually replace the power supply in situations like this and all is well.
Jan 11, 2010 | Dell Dimension 4600 PC Desktop
Have a dell dimension 4600. I have a blinking
The two biggest culprits would be:
the power supply and the motherboard.
I'd start with the power supply since it's cheap and easy to install.
Find a local computer shop that sells 'em.
Make sure they've got a 100% return policy.
Swap 'em, if it works problem solved.
If not it's probably the motherboard. You could always have a local tech check it out.
Make sure they provide FREE diagnostics. It shouldn't cost you anything to have ti looked at.
Jun 19, 2009 | Dell Dimension 4600 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Problem with Dell 4600 Dimension Computer
on the computer you will see 4 leds labled A B C D. make sure all are Green. if not there is some issue withe the system.
Jul 04, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
323 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
