Question about Brother HL 5040 Laser Printer
Brother hl-5040...not working..
Have had printer continuously stop before job was done. Often I had to press "go" button to finish the printing job. The other day it went completely out--no lights or anything, then about 2 days later it decided to work on its own. Now it's been 3 days since it has worked--making this the 2nd time it's happened....
Printer will print test page but says i need to update driver to support windows xp
Posted on Mar 19, 2008
How to stop and cancel printing on brother Hl-2240d printer on a Mac Pro computer
Most printers can be stopped by going to your control panel and selecting printer and then find the command that cancels the printing job. Try this teaching video:
https://www.youtube.com/watch?v=YXIM_17IIl0
Feb 28, 2015 | Brother Hl2240d - Hl-2240d Laser Printer...
How to Cancel Printing in a Brother HL-2135W printer
Start by pulling the paper tray out to stop further pages being printed without jamming the printer up.
Then go onto your print queue on your computer and delete the job that is printing 50 pages.
If it dissapears then put the paper tray back in and it may print out the last page or two that were in the printer buffer.
If it does not dissapear from the print queue then turn the printer off and try to delete the job again.
Once you have ordered the job deleted then you can turn your printer back on and put the paper tray back in and allow it to continue. It should only print out the last page or two and then the job will dissapear
Sep 15, 2014 | Brother Hl-2135w Compact Wireless Mono...
Why brother hl 2140 error light
The error light indicates something is wrong with the machine. The error light in combination with another light indicated that the problem lies with that item.
If there is an issue with a job not being able to be printed you can press the go button to allow it to continue (Normally happens if you send a job to the printer using paper other than what the printer has in it)
Aug 29, 2014 | Brother HL 2140 Laser Printer
How to Stop Printing while it is Printing ?
Start by pulling the paper tray out. This will cause the printer to finish the page it was on when it was interrupted rather than paper jam somewhere in the machine.
Once you have interrupted the print job this way then you can cancel the print job from the PC and then once that has been done turn the Printer off for a few minutes to clear the memory buffer.
Turn it back on and it should be cleared.
Mar 13, 2014 | Brother HL-2135W Mono Laser Printer Page...
Driver download
Here is the link to the downloads for this model:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=hl5040_all
Here is how got there:
Go to http://www.brother-usa.com/Support/
Select "Software Downloads"
From 'Select Product Group' menu, select, Printers (HL Series)
Select your model, the HL 5040 and click view.
Under 'Your Results' select HL-5040 Downloads on our Online Solution Center.
May 10, 2013 | Brother HL 5040 Laser Printer
How to turn on the toner save for the hl 5040?
hello, in the print manager for this printer, when you pull it up, the advanced section has 2 boxes listed toner saver, the options are yes or no. make sure to select yes
Oct 11, 2010 | Brother HL 5040 Laser Printer
Drum light comes on my Brother HL-5040
You need to reset the drum counter. Open the front door and hold the go button until all the lights flash. Shut the door, ready to print...If you press the go button 3 times it will give you a printout that shows the usage level of the drum.
Jun 25, 2009 | Brother HL 5040 Laser Printer
I have a problem with my Brother HL-5040 laserprinter: There was one paper stucked between de components of de rollers. I pulled it out very carefully - no problem.  But now the lights "STATUS" and...
Hi...
disconnect the power and usb cable from the back of the printer and press and hold down the power button for 30 sec and then reconnect the cables and try again...open the backdoor and try to move the rollers in upward direction.
Regards
debroy
Nov 25, 2008 | Brother HL 5040 Laser Printer
Badly jammed Brother HL 5040 B&W laser printer
If you remove the drum unit and cartridge it will all come out in one go.
Open the right hand end. The black T700 cartrige will be seen and it looks as if it is screwed in. However it is NOT just get a firm grip and pull the entire unit out (It snaps in and is quite tight... keep pulling it will come and there are no clips to break as you pull)
As it is removed, all the paper will come out in one go. A bit daunting if you have not done it before. Refit is the exact reverse, push it in quite firmly and it will latch back in place with a pleasing clunk! Hope that helps.
May 25, 2008 | Brother HL 5040 Laser Printer
Brother HL 5040 Laser Printer Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
