Question about Microsoft Computers & Internet
I cant make mde file of my database
My db forms are designed with vb code. But i dont have any vb code in startup form. when i try to make the db in mde one its getting long time
From the modules object I selected debug menu and from there chosen compile option.
The problem was solved within a second.
Posted on Jun 16, 2009
What is the extension file name for a microsoft access file?
According to Wikipedia:-
Access Project .adp
Access Blank Project Template .adn
Access Database (2007) .accdb
Access Database Runtime (2007) .accdr
Access Database Template (2007) .accdt
Access Database (2003 and earlier) .mdb
Access Database, used for addins (2,95,97), previously used for workgroups (2). .mda
Access Database Template (2003 and earlier) .mdt
Access Workgroup, database for user-level security. .mdw
Access (SQL Server) detached database (2000) .mdf
Protected Access Database, with compiled VBA (2003 and earlier) .mde
Protected Access Database, with compiled VBA (2007) .accde
Windows Shortcut: Access Macro .mam
Windows Shortcut: Access Query .maq
Windows Shortcut: Access Report .mar
Windows Shortcut: Access Table .mat
Windows Shortcut: Access Form .maf
Jun 03, 2010 | Microsoft Office Access 2003 (077-02871)...
How to make the library managment project with VB.Net & using MS Access as for database.& please help me out what code should I use for making that project?
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
Nov 19, 2009 | Computers & Internet
How to make a code for log in using database?
RIGHT CLICK ON MY COMPUTER AND SELECT THE MANAGE AND SELECT USER AND GROUPS CLICK YOUR USER ON WHICH YOU WANT CREATE PASSWORD RIGHT CLICK THE USER AND SET PASSWORD AND FILL THE PASSWORD AND ENTER NOW YOUR PASSWORD WILL SET ENJOY
Oct 21, 2009 | Microsoft Visual Basic 6.0 for PC
How to create crystal report in asp.net with vb script code
You can open the Crystal Report (should be installed with Visual Studio first) after you designed your database, then you have to connect the Crystal Report to the right database (the one which you store financial information in your case), then you can create your report easily by putting the desired variables and designs. Then you have to call for that report with a code within visual basic.
Apr 15, 2009 | Computers & Internet
How to i connect html page to microsoft access database
YOu need to be using any server side language assciated to the html page or at the least javascript to connect to the DB..
Check this sample..
http://www.daniweb.com/forums/thread84847.html#
Apr 01, 2009 | Microsoft Office Standard for PC
Hi all i want to launch a form when i click the data base file in MS access 2003 (the form is created inside the mdb file of access)
hi,
on MS Access 2003:
goto Tools Menu --> Startup --> select your form for "display form/page" dropdown
uncheck the "display database window checkbox and display status bar checkbox
Hope this helps.
Thanks.
Apr 01, 2009 | Microsoft Access 2003 for PC
I WANT TO CREATE A DATABASE FOR PDF FILES USING MICROSOFT ACCESS
have to follow few steps.
1. new database - give any name
--> design table
e.g id, name and file (the datatype of the file should be hyperlink other wise it wont work)
--> enter some records (in file field write a, b ,c)
--> when you put record in file field then click on hyperlink option on top.. (like first record id=1, name=fahad, file=A) select the A and click on hyperlink option on top and give the hyperlink of the pdf file
--> design the form
--> run the form
--> click on desired file
--> it will open
--> looks complicated but its easy
it will work definitely
Mar 24, 2009 | Microsoft Access 2003 for PC
Accessing data
Dear reader
Place an ADODC control on your form in VB.
In the properties of the ADODC control goto the TAB General.
click "Use Connection String. With the button Build you can point to your database.
Thats it.
With the following code you can connect to db:
With Adodc
.RecordSource = "SELECT * From YOURTABLE"
.Refresh
End With
Now you have the table in the adodc control.
you can now do this:
Label1.caption = Adodc.Recordset!YOURFIELD
YOURTABLE = the name of your table in the database.
YOURFIELD = the fieldname in YOURTABLE you want to show.
Kind regards Fred.
Jul 04, 2008 | Microsoft Office Access 2003 (077-02871)...
View Reports
Hi, There a couple of different way you could do this and I have put two lots of VB code below that you can modify and use. Firstly you create the Combobox list by choosing the option that you will type the values yourself, you then type in all your report names on each line. After that you can then go to the VB code editor and paste my code in and modify it by changing my report names, (Customers) etc to your report names. Make sure you choose the Combobox and the On_Click option in the VB editor to paste the code into.  I like the first method better which checks the value of the Combobox and then opens the corrosponding report in the maximised form. The second method does the value check before running an assigned macro to open each report. With this you must first assign macros to each report in Access.  Remember each of these bits of code must be placed between the "Private Sub" heading and the "End Sub" ending, and change the "Combo23" name to reflect your combobox too. If you need a hand just email me.
First Method
If Combo23.Value = "Customers" Then
    DoCmd.OpenReport "Customers", acViewPreview, acWindowNormal
    DoCmd.Maximize
ElseIf Combo23.Value = "Customers 1" Then
    DoCmd.OpenReport "Customers1", acViewPreview, acWindowNormal
    DoCmd.Maximize
ElseIf Combo23.Value = "Customers 2" Then
    DoCmd.OpenReport "Customers2", acViewPreview, acWindowNormal
    DoCmd.Maximize
End If
Second Method
   DoCmd.RunMacro "Macro1"
   DoCmd.Maximize
    DoCmd.RunMacro "Macro2"
    DoCmd.Maximize
    DoCmd.RunMacro "Macro3"
    DoCmd.Maximize
End If
Oct 28, 2007 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
