Epson b - 510 DN printer error printer restart 0x95 error
Epson B-510 DN printer error printer restart 0x95 error - how do Ifix this. Have tried turning on and off and also reinstalling software. No paper jam.
Inky
  • 705 Answers
SOURCE: Epson Cx3200 paper jam
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
Posted on Feb 17, 2008
jackboy
  • 2985 Answers
SOURCE: Epson Paper Jam Error
Discover the rest procedure for your particular printer
Usually involved switching off- then holding down a couple of button whilst you switch on
for example Service and stop.
Try www.fixyourownprinter.com for more info
or
www. stevesdigicams.com/forums
Posted on Jun 10, 2008
SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
Posted on Jul 03, 2008
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
IrishDruid
  • 2712 Answers
SOURCE: Lexmark X6570 printer - Cleared
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Nov 11, 2008
Printer has locked up with a 0x95 PRINTER ERROR
We have had the same problem. Not 100% sure, but we think it is to do with the ink pad (where the head is cleaned) getting full to saturation - our machine had ink sitting under the maintenance box, and the digital eye which checks the head being dirty (inked up) because of the ink pad being full. The problem will clear if you unplug the printer completely and leave it for a while, but we suspect the only real solution is to take it apart, remove and replace the sponge and clean the eye. Epson service will probably not do this for you and will say it is too expensive and not worth repairing. Hope this helps.
Jul 15, 2014 | Epson B510DN InkJet Printer
0x95 error
Epson Printer Error 0x95 occurs when the printer head is saturated,i.e; cleaned. Error may be due to installation or uninstallation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Steps to Fix Error 0x97 in Epson Printer:
Solution 1: - Check Epson Printer Ink Head
Check Epson Printer Ink head. Generally, Printer ink is dirty meanwhile it is inked up properly because the ink pad is full. Often due to unbalance ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
If this step is not working to fix Error Code 0x95, then go to next step.
Solution 2: - Manually Perform Steps with Epson Printer
  • Try to switch on your Epson printer.
  • Then "press+hold" together to stop ink power buttons.
  • Wait for sometimes while the printer switches self OFF.
  • Next switch back ON and your error should have gone.
Solution 3: - Run the System Under Safe Mode
You should try to run the computer under safe mode, and then you may receive a message from the system about whether your error existence effectively solved.
Solution 4: - Uninstall Current Installed Software From System
  • On your Windows "Start" button, go to "Programs and Features".
  • In the "Control Panel", tap "Programs", and then tap "Programs and Features".
  • Choose that software program that you have just installed, and then tap on "Uninstall" button.
You can visit Epson Printer Support Number if you are still unable to resolve the Error.
Apr 01, 2014 | Epson B510DN InkJet Printer
Epson B- 510 DN printer error printer restart 0x95 error
Epson Printer Error 0x95 occurs when the printer head has gone empty or you can say that it has become completely saturated. The reason for this Error may be issues in installation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Printer ink becomes dirty because the ink pad is full. Due to unbalanced ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
  • Switch on your Epson printer.
  • "press+hold" together to stop ink power buttons.
  • Wait for sometime while the printer switches self OFF.
  • Switch ON again and your error should have gone.
You should try to run the computer under safe mode, and then you may receive a message from the system about your error existence is effectively solved or not.
Jan 24, 2014 | Office Equipment & Supplies
Epson B-510n inkjet Printer Shows Printer error Code 0x95
Read page 131-218 on your user guide for a list of errors and solution based on your b310
If you don't have user gude download on the link below
other more hrlp visit https://cbrtechsolutions.net
Sep 24, 2013 | Office Equipment & Supplies
Epson B510 DN error 0xf3
SAME PROBLEM WITH ME :(, DONT FIND ANY SERVICE MANUAL OF EPSON B510DN
Jul 02, 2012 | Epson Office Equipment & Supplies
Epson B-310n inkjet Printer Shows Printer error Code 0x95
Hi, i would like to know, does anyone have experience with this error? In service manual also is not informations about it! I checked with adjustment program for last errors, and there showed 95 H : VOUT. can anyone help me?
for more help visit https://cbrtechsolutions.net
Jun 17, 2011 | Epson Business Inkjet B310N Network Color...
hear is the link you check the our solutions
manualslib.com/manual/432107/Epson-B-310n.html?page=131
for more help visit CBR Tech Solutions
Jun 16, 2011 | Office Equipment & Supplies
Perform the nozzle check and print headcleaning.
& See "Checking the Print Head Nozzles"on page 151
& See "Cleaning the Print Head" on page153.
Press the OK button to recover from errorstatus
Mar 09, 2011 | Office Equipment & Supplies
EPSON C1100 E 510 EROR
E510 idicate the ROS motor faulty... PWBA MCU could not receive signals output from SOS Sensor in ROS within the specified time.
Possible cause ROS assy, PWB MCU, Harness PWB, or LVPS..
but before you change any.. make sure all your cover are close properly..normally the fuser cover interlock switch can cause this error as well.. check the switch at the right side of the fuser cover...make sure it's not deform .
May 21, 2010 | Epson Aculaser C1100 Printer
Epson stylus photo rx 510 - turn on, wont do anything says error then scrolls scanner error
i have a epson stylus photo RX510 wont install into my computer with out the cd any ideas how to fix this
Aug 27, 2008 | Office Equipment & Supplies
Open Questions:
My Ricoh 3035 / Savin 8035 prints uniformly light pages, and tells me to add toner, with a FULL toner bottle. The developer unit itself is completely packed with toner. There are no other errors set. The issue described is recent, within the last 500 copies. Prior to that this machine was running perfectly. I've had this copier for a couple of years. It was used. It NOW has 617,871 prints/copies/faxes as of today. I replaced the developer unit remanufactured and new developer at 591,810. The transfer belt and cleaning blade are new at 607,638. I replaced the PCU with a completely remanufactured unit at 607,688. The fuser was replaced with remanufactured unit also at 607,688. I was STILL having some issues with bad quality copies, so I narrowed the matter down to a defective drum in the remanufactured PCU. I replaced the drum, and at THAT time, I installed every part in the Savin Maintenance Kit PMB082150K, which I previously received with the copier. I also replaced the PCU Entrance Seal and tape the long mylar one at the top of the drum. When I installed the developer unit, I initialized the settings, pursuant to the Service Manual, and the same with the drum, and the appropriate one each time I previously cleaned the ID Sensor Today, I went through the trouble of replacing the ID Sensor, initialized the same, and it made no difference. The copier has run just fine for the last couple of months, and then as I stated in the question, about 500 copies ago, all of the copies suddenly became light. No, it's not the density setting. I've done everything except do a factory reset. Incidentally, I have the Ricoh 3035 Service Manual, and also the Parts Manual. Experientially, the only computers I have ever purchased are 2 of them, for my office, in 10 years. Other than that, I have built every computer I've ever made, from parts. As far as this copier, I have done the copier maintenance, per the maintenance schedule, myself, and when it appears that maintenance needs to be done. This problem however, is driving me nuts. As I said, the only symptoms of the light copies are that add toner light that comes on periodically, and toner absolutely packed into the developer unit entrance such that its spills out when I remove the PCU. One last thing, and this is an when all else fails kind of thing: since the toner bottle is full, I open the front door, and using a channellock, I fix the add toner problem by rapping very lightly on the end of the PCU, and the developer unit! This DOES fix the toner out problem every time, but it does NOT fix the light copies. Simply opening the door, sliding the toner carrier out, putting it back, and then closing the door, and repeating that process a couple of times sometimes also works.
Jan 21, 2019 | Ricoh Aficio 3035 Digital...
806 people viewed this question
k24674
Marvin
Marvin
