Question about Panasonic Lumix DMC-FZ8 Digital Camera
Wide/telescopic lens stuck
Although the lens works properly when turned on and off - and focusses properly when photographing - there is no movement at all when I use the wide/tele button. It seems to stay in the same position no matter what picture setting I have the camera on.
It is about three monthsold and Iknow it has notbeen dropped!
  • 1 more comment
  • mccasita Apr 14, 2008
    wide/telescopic lens stuck - camera only about one month old.
  • papeep Aug 24, 2008
    Mine does the same thing. It appears that the zoom switch is broken, as I'm unable to zoom in on photos in "play mode".
  • britnorton Dec 26, 2008
    The lenses seem to be working fine, it's the zoom switch itself that doesn't work. Is there a way to fix this on my own, or if not, about how much will it cost to get it fixed?
This might be the problem:
http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/
Posted on Dec 29, 2007
Pieces in Wide Field Finderscope are loose. Telescope 78-5660 60MM
PDF]Telescope Instruction Manual - Bushnell
bushnell.com/getmedia/...5f19.../78-9500.pdf?...
Bushnell CorporationParts Diagrams. 4. 1. Red Dot Wide Field Finderscope. 2. Eyepiece. 3. TelescopeMain Tube. 4. 60mm Objective Lens. 5. Latitude Lock Knob. 6. Tripod Leg. 7.
[PDF]voyager® 6 inch dobsonian telescope model 78 ... - B
Jan 01, 2016 | Bushnell Optics
My canon T3i wont focus with either lense?
Most likely your camera is set to M manual focus. There's a little switch on the side of the camera that has S/C/M. The S is for single servo focus so it focusses on one subject and does not re-focus. The C is for continuous for action and movement and the camera continuously re-focusses, and the M is manual focus.
The other possibility is that both lenses are switched to Manual. There is a switch on the lens that says M/MA. Be sure it's on MA
Aug 18, 2014 | Canon EOS 600D Rebel T3i Digital Camera...
How to use the telescope and set it to see images
It depends on what kind of telescope you have.
The method of use is somewhat different.
Also we have to know what kind of mount you have,
equatorial or alta-zimuth.
Does your telescope have a go-to computerized mount.
The simple answer for a manually controlled telescopoe is:
1. Put in an eyepiece that has the highest number printed on its side - usually 25 mm, or 26 mm -
2. Aim the telescope at what you want to see in the night sky.
You can aim by sighting with your eye along the length of the telescope or by using the finder scope (a tiny telescope usually attached to the body of the main telescope).
3. After finding a target to look at, turn the focussing knobs slowly in one direction - if the image is getting blurrier then turn the knob in the opposite direction. Do this slowly and gently, until the image looks sharp.
4. Start by looking at a large target such as the moon. It is very easy to find and to aim at.
5. Get some books on beginning amateur astronomy. You can find a wide selection of these at your local library, or Google the internet for information of amateur astronomy.
I hope the above outline helps you to get started.
walt
Aug 21, 2013 | Citiwell International Orbitor 5500...
I am a beginner looking for a good telescope. I am currently looking at a Celestron Skywatcher telescope. There are three lenses which comes with it: super wide 10mm. lens as well as a wide angle 25 mm....
Magnification is the LEAST important property of a telescope. Quality optics and aperture are much more important.
The best bang for the buck is a reflector style telescope ion a Dobsionian mount. You get the most aperture for the least amount of money. Like this one--
http://www.telescope.com/Telescopes/Dobsonian-Telescopes/Classic-Dobsonians/Orion-SkyQuest-XT6-Classic-Dobsonian-Telescope/pc/1/c/12/sc/13/p/8942.uts?refineByCategoryId=13
The scope above has 6 inches of aperture and is mounted on a very stable alt az mount called a Dobsonian mount.
www.telescopeman.org
www.teleswcopeman.us
www.telescopeman.info
Aug 23, 2011 | Optics
I have a makusutove 150 1800 telescope and I cant seem to get it to focus correctly - it seems as though the mirrors are focussing the light behind the viewing lens. I can get a focussed image if I hold...
You do not have enough BACK-FOCUS, you need an extension tube for the focuser like this one:
http://www.skiesunlimited.net/index.php?CategoryID=132
Buy the correct size for the focuser hole--
Jan 21, 2011 | Tasco 49114500 Spacestation(r) 114mm...
Basically, the lens is stuck out of my Samsung P12...
the lens stuck out of my Samsung SL420.
May 20, 2010 | Cameras
My camera will not focus. I have a 50mm lens and 200mm and neither will focus
Which exact lenses are you trying to use? The N2000 (aka F301) is a manual focus camera so if you're trying to use autofocus lenses you have to focus them manually. Sorry if this seems an insulting suggestion, but you did state "my camera will not focus" and I've learned that on FixYa it's best not to assume any prior level of knowledge with regard to those who post questions.
The next thing to check is whether the viewfinder has an eyecup attached, if so slide it upwards to remove it as sometimes they have a corrective lens fitted if the previous user needed corrective optics. If your vision is fine (with glasses/contact lenses if necessary) then a corrective lens on the viewfinder may make things look blurry.
Other than that, the only other possible cause (other than a pair of broken lenses) is if the focussing screen has become dislodged downwards (or somehow fitted upside-down) then the viewfinder image will be unsharp. Officially the F301/N2000 had a fixed focussing screen but it could be replaced with one of three designed for the higher specified F501 (which does have autofocus), and if not seated correctly you'd get the focussing issue you describe.
You can test if the focussing screen is the problem in one of two ways:-
1. A visual inspection (you may need to get a more experienced photographer to take a look at it);
2. Set the lens to focus at infinity and at the widest possible aperture and take a photograph of a distant object (ignoring the blurred viewfinder). process the film and inspect the photo. If it's sharp then you have a focussing screen problem. If not, then it's a lens problem.
If the problem is a poorly fitted focussing screen then it may just need reseating or to be removed and refitted. It's vital to do this in a dust free environment and to avoid getting fingerprints on the screen. Some screens sit in a hinged frame which then clips into place when pushed up, others push into a pair of clips towards the top rear and then the front is held in place by a spring clip: it's been a long while since I worked on the F501 or F301 so I don't recall which system is used.
Courtesy of Norman Butkus' website, click here for a free Nikon N2000 user manual.
I hope that you've found my answer to be of use, if so please return the favour by rating my answer.
Feb 06, 2010 | Nikon N2000 35mm SLR Camera
Auto focussing problem with nikon d90
This is most likely a problem with the lens. Do you have the switch on the side of the lens at 'A'? Are you able to focus manually? It is a common fault that can occur if the lens has receive a knock or the camera has been dropped. Also, grit or sand in the lens mechanism could cause this. It is recommended that you send this camera to a qualified service centre.
Nov 22, 2008 | Nikon D50 Digital Camera
Black dot.
Ensure focusing is spot on. if your image is a black dot surrounded by white light (like a doughnut) then your not in focus. Look at making a Hartmann Mask (really easy, just google for it), which fits over the front lens. It has 2 or more holes in it,this means when you look through the eye piece you will see double images, adjust focus until the images merge into one (if the images go further apart turn the focuser the other way), when they are merged remove the mask and presto you should be in optimum focus. Always remember telescopes are very sensitive and focussing requires delicate adjustments.
Regards and Clear Skies
Carl
Dec 26, 2007 | Celestron NexStar 4 SE Telescope
Focus Issues
Try tightening the grub screw that fastens the knob onto the shft that it turns.
Better still, buy a flexible extended focusser which makes focussing much easier. Check on eBay for "Meade flexible focus"
Sep 27, 2007 | Meade Telescope
Panasonic Lumix DMC-FZ8 Digital Camera Logo
181 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
