Question about Nokia N73 Cellular Phone
Want to put an swf file as a screen saver - Nokia N73 Cellular Phone
How do I get rid of screen savers I have one with underwater,fish swimming,bubbles and behind that one I have a Halloween on with a black cat, bats,etc.
If your are running Windows XP you have have several options. USE OPTION 3 ONLY if you are comfortable working with system files and as a last resort.
  1. Open your "control panel" > "Display". This will open your "Display Properties" window. Click the screen saver tab and set your screen saver to "[None]" This setting will not put your monitor into any screen saver mode.
  2. Open your "control panel" > "add or remove programs" usually a downloaded screen saver will appear in this list, find the appropriate file/screen saver you wish to remove & click remove. If you wish to permanently remove the screen savers.
  3. I strongly suggest you do full back up of your system or at minimum create a "Restore Point" BEFORE you do any of the following suggestions!!! You could also search for the screen saver files. Click "Start" > "Search" This will open the "Search Results" Dialog window. look in your local hard drive where XP OS is installed. This usually is your c: drive. In the "All or part of the file name:" box enter "*.scr" this will give you a list of screen savers in your "C:\WINDOWS\system32" folder. Be VERY CAREFUL working in this file!!!! If you delete the wrong file your OS System may quit working properly or altogether! I am not sure if a downloaded screen saver has the file extension ".scr", I think they do. Maybe someone else could clarify that for both of us.
GOOD LUCK!!!
Oct 18, 2009 | HP Computers & Internet
Video
how to create your own .swf video and post up on internet.
SWF info:
The Flash File Format (SWF) was designed as a very efficient delivery format that was initially designed to deliver vector graphics and animation over the Internet. It was designed to meet the following goals:
On-screen Display—The format is primarily intended for on-screen display and so it supports anti-aliasing, fast rendering to a bitmap of any color format, animation and interactive buttons.
Extensibility—The format is a tagged format, so the format can be evolved with new features while maintaining backward compatibility with older players.
Network Delivery—The files can be delivered over a network with limited and unpredictable bandwidth. The files are compressed to be small and support incremental rendering through streaming. SWF is a binary format and is not human readable like HTML. Macromedia Flash (SWF) uses techniques such as bit-packing and structures with optional fields, to minimize file size.
Simplicity—The format is simple so that the player is small and easily ported. Also, the player depends upon only a very limited set of operating system functionality.
File Independence—Files can be displayed without any dependence on external resources such as fonts.
Scalability—Different computers have different monitor resolutions and bit depths. Files work well on limited hardware, while taking advantage of more expensive hardware when it is available.
Speed—The files are designed to be rendered at a high quality very quickly.
Don't want to do any code work?
if you really want to share a video or Dvd moive and want to post up on the internet, or send the SWF file to your friends through mobile device, the simplest way is to encode the video to .SWF first
What you need?
1)rip DVD to .swf
DVD to SWF Converter can easily help you convert DVD to SWF and Flash video, which can be played with Flash Player. iOrgSoft DVD to SWF Converter enables you to convert DVD moive, whether it is protected or not, to SWF/FLV. In addition, DVD to SWF Converter allows you to rip DVD audio to MP3, WAV, AAC, AC3. with the powerful editing functions, You re allowed to select any favorite part of title or chapter to convert. Oppositely, you can join several DVD chapters or titles into one file provided tick the "Merge into one file" option. DVD to SWF Converter offers other rich options such as DVD video crop, special effect setting, subtitle and audio track selection, etc.
2)convert video to .swf
SWF Converter is an easy to use application for converting your video to SWF format. Almost all popular video formats are supported, including AVI, WMV, ASF, 3GP, VOB, MOV, MPG/MPEG2, FLV(Flash Video). With iOrgSoft SWF Converter, you can share your favorite videos on the web easily and quickly SWF Converter offers a variety of video editing features such as video trimming, video cropping, video capturing, video effects. As to experts, you can get your customize video by setting the combined-parameters for your video. explore yourself now.
Mar 31, 2009 | Macromedia Flash MX
How to make mobile screen savers from flash
It's not too hard, if you know flash, so just make your flash vision in Adobe Flash and then  export it in SWF format. nowaday, you know that many phones could read swf files (Flash files) and if your cell phone could read swf file, so you can set it as screensaver, I provided some useful links, I hope they could help you.
There's some useful softwares that help you to make flash screensaver, check these links:
http://www.zbsoft.net/flashscreensaver/
http://wareseeker.com/download/flash-screensaver-maker-3.368.rar/1f8bc48be
http://www.junglemetal.com/
http://flash-screensaver-creator.junglemetal-software.downloadsoftware4free.com/
http://www.flashjester.com/?section=tricks_creator
http://www.sofotex.com/Flash-Screensaver-Creator-download_L8520.html
And finally check this software: http://download.cnet.com/3001-2409_4-10406608.html?spi=a73e986a7038994b1086f35006420cc1
Mar 23, 2009 | Computers & Internet
*.swf to *.fla
You can use a program such as the one at the link below. Its a Shock Wave Flash Decompiler
http://www.sothink.com/product/flashdecompiler/
Nov 07, 2008 | Macromedia Flash MX
My computer will not open swf files. how do i correct that. D
check your related software for swf files, whether it is working properly or not?
usually, it is a macromedia flash player files. so, try to update or install the flash player software in your computer. then open the appropriate swf files.
or
you can install swf opener software to open these files and view the flash and animated files.
Jul 21, 2008 | Computers & Internet
Dialpad and calender problem
i overwrite two files in the swf folder: dialpad and calender files.
now i cannt make any calls using the dialpad as it shows a black screen when i click on the dialpad button
Apr 05, 2008 | LG KU990 Viewty
Plat swf files sequentionally from xml
I've finished your requirement almost but how do you read the swf files from the xml one by one? My code will parse the xml and open the swf files one by one and so you can only view the last swf file.
var myXML:XML=new XML();
myXML.ignoreWhite=true;
myXML.onLoad=function(success){
    if(success){
        for(var aNode:XMLNode = this.firstChild.firstChild;aNode!=null;aNode=aNode.nextSibling){
            loadMovie(aNode.firstChild.toString(),_root);
myXML.load("sampleFiles.xml");
And your sampleFiles.xml should look like this:
<swf>
  <swf1>sample1.swf</swf1>
  <swf2>sample2.swf</swf2>
  <swf3>sample3.swf</swf3>
</swf>
Oct 08, 2007 | Macromedia Flash MX
Nokia N73 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
